Thread: Spa runs in overflow mode all the time
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    This is a an interesting question, as my pool also runs in overflow mode all the time. I'm certain that it could be programmed to bypass the spa, because it creates a "closed loop" for just the spa in spa mode. Therefore I just need to use that "closed loop" and focus it on the pool mode........ somehow. Sounds easy, but programming that sucker is tough for the novice!
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    38,275
    Re: Adjusting return jets...
    Some plumbing setups have a spa makeup valve on the pool mode that may not let you automatically switch to pool only.
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Thanks for the heads up, Jason. Sounds like I need to ask a few questions about my setup.
    Re: Spa runs in overflow mode all the time
    What brand of automation system do you have? All of them should have a setting for what you want, but it can be tricky to find on some models.
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Do you mean to say that all your return water goes through the spa and then over the spillway into the pool?
    Nothing ever comes out of your pool returns?
    Sounds like some valves and/or actuators need adjusting. Possibly some programming too
