Thread: Need to add more sodium bromide
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    My 425 gallon tubs needs about 2.5 ounces of sodium bromide at startup. I only have 0.8oz right now and I'm unable to get to the store. I do have Leisure Time bromo tabs, and if I understand correctly, I can use those to help with my bromide reserve, it'll just take a little bit to convert. Any idea how many tabs I can crush and throw into the water? Thanks
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Need to add more sodium bromide
    You could just add some tabs to a floater and maintain bromine levels with that for about a week or so, depending on usage. After 2-3 tablets have fully dissolved, you'd have a sufficient bromide reserve, assuming it is BCDMH (Bromochloro-5,5-dimethylhydantoin) based tablets. If you don't have an ozonator, you'd likely not have to intentionally add any more tablets or bromide until you drain and refill. If you have an ozonator, bromide is slowly broken down and you may have to add more over time. There is no direct way to measure bromide from what I know and if you shock with bleach, you can't tell if you're measuring free bromine or free chlorine if the bromide bank is exhausted.
    Isolated Spa - 345 Gallons
    Mar 2007
    San Rafael, CA USA
    12,082
    There's a rather complicated way to determine the bromide bank by using ammonia, forming bromamine, and using an ammonia test kit (which explicitly tests for monochloramine), but it's not worth describing in detail.
