Results 1 to 18 of 18
Thread: skimmer to pump issue ????? help!!
    Mar 2015
    Houston TX
    45
    My skimmer drains and begins to suck air whenever I have my pump on high. It runs fine on low but I am concerned because I am wanting to slam and then utilize the SWG and from time to time I will need to put it on high to go to 100%. I have changed out to a new filter because the other one needed a deep cleaning. I have cleaned it and am planning on storing it in a plastic bag and then alternate between the two, will this be a problem? Also any suggestions on the pump draining the skimmer is appreciated, thank you. Oops one more question..... I tried the skimmer sock and my husband was concerned that it might be part of the problem so he had me remove it, can anyone give me more info on the skimmer sock?
    21x42, 23000K AG ClearwaterII Cartridge Waterway 2HP 2 speed July 2014 TF-100 SWG aquarite with Tcell
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: skimmer to pump issue ????? help!!
    So, if you have good flow into the skimmer, it does it without a sock on it? Unless they are clogged, socks work fine.
    If you do it sounds like you have too much pump. Is this a new pump on the pool? You mentioned another filter, but what about the pump?
    Essential Links:
    Mar 2015
    Houston TX
    45
    The entire pool is less than a year old. It was initiated last July we don't remember it doing it last year however it is a 2HP pump
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    How high up is the pool water level on the skimmer face? Should at least be halfway and you can 3/4 and see if that helps any.
    Mar 2015
    Houston TX
    45
    It is half way and I have thought that adding water to make it about 3/4 up. Do I need to have my pump on high to run the SWG at 100%? The instructions say so but why?
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Do you only have the one skimmer ? Is there a floor drain ? If have more than the one skimmer can you adjust to pull some water from another source too ?
    I was looking at a Doughboy AGP about the same size and it has a floor drain and dual skimmers with a 2 HP pump.
    Solar Blanket, Well Water, Borax Added. 76
    Apr 2010
    East Texas
    9,655
    Your SWG is looking for a certain amount of gallons per minute----flow rate---to run through it.
    Mar 2015
    Houston TX
    45
    I only have the one skimmer it is a wide mouth and no drain. Any ideas how I would "pull water from another source"?
    There are two possible causes. Either the pool water level is too low, which seems unlikely given what you said, or the weir door (swinging door inside the skimmer) is stuck so that it doesn't move properly and is blocking the water flow.
    Check the weir door and make sure it moves freely and there isn't any debris blocking the skimmer. If that doesn't help, try adding more water to the pool so that the water is 3/4 of the way up the skimmer opening.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    You'd need to add a drain or an additional skimmer so you aren't taking all the water from the one skimmer. Not real practical but it is something you could do should you need to drain it in the future.
    It does seem like a lot of surface area for one skimmer, just my opinion.
    Mar 2015
    Houston TX
    45
    I agree about the surface area of the pool versus one skimmer. How would a drain help? As for the weir door yes it is free flowing. We have talked about adding another skimmer and is something we could do if that would help.
    Something strange is going on here. Any common skimmer should be able to handle a very high water flow without much trouble. How large is your pump?
    Mar 2015
    Houston TX
    45
    LOL leave it to me to have a weird one! I have a waterway cartridge filter with a waterway hi-flo 2hp 2 speed pump and a widemouth waterway skimmer. I have replaced the filter and am not using the "skimmer sock" so as to not reduce flow. It runs fine on low. if I release air from the filter on low there is none. But if I place it on high it will drain the skimmer and then hesitate and allow the skimmer to catch up and then does it again resulting in a pulsating type action. It is all hard plumbed. After just a few minutes if you release the air in the filter it has a huge amount????? Please help if you have any ideas I am filling it to 3/4 of the skimmer now and will recheck.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    What he said. We know it's 2hp but can you post the pumps specs or it's model number ??
    If you had a drain you could use a valve or valves to control how much water you pull from each. Like both full open or or the second source (second skimmer or drain) open just enough that the main skimmer doesn't suck air.
    Can you post a picture or two of the skimmer ??
    Mar 2015
    Houston TX
    45
    30,432
    Just a wild guess but your water looks too low. Bring it up to those two black dots on either side and see if that doesn't cure the issue.
    Mar 2015
    Houston TX
    45
    I am adding water now
    Mar 2015
    Houston TX
    45
    For everyone following this thank you and yes I think additional water is going to fix it. In order for those "black spots" to be covered that is about 3/4 full but it seems to be able to keep up. So thank you!!!!! One last question does the drain go thru the pump?
