Results 1 to 8 of 8
Thread: Evaporation?
    Mar 2015
    Atlanta, GA
    1
    Evaporation?
    Just curious, how much evaporation should I experience on average? I have an approximately 18,000 gallon pool and I notice about an inch drop in water level per week when there is no rain. I don't have any leaks that I'm aware of. The plumbing is not leaking in any visible areas. Could this be evaporation, or should I be concerned about a leak?
    Thanks!
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Re: Evaporation?
    That's consistent with what I observe with my pool, as long as it is warm and dry. If it's still cold outside, then I might get a bit suspicious.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Evaporation?
    Welcome to the forum Gabbagabbawill
    Do you cover your pool ?
    It also makes a difference if your in the city or out in the country. I have a pretty good wind being out in the open so 1" a week doesn't sound too bad. I keep mine covered.
    Solar Blanket, Well Water, Borax Added. 68
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Evaporation?
    Not unexpected. Depending on wind, water/outdoor temps it can vary, but an inch a week, pretty normal.
    Essential Links:
    Re: Evaporation?
    We have humid summers with hardly any evaporation. But in the spring and the fall when the humidity is low there can be a surprising amount of evaporation.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Evaporation?
    Welcome!
    I've been losing a lot lately, too. Besides being warm, it's been breezy, and wind affects evaporation a lot more than temperature in my experience.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Evaporation?
    My PB installed an autofill on our pool. He said pools with autofills don't leak or evaporate.
    Sep 2014
    North DFW
    161
    Re: Evaporation?
    Quote Originally Posted by pooldv View Post
    Your PB was right! Mine hasn't lost any water at all, and my PB also installed an autofill.
    39' x 18' IG 3.5X4.5X9 34k gallon w/ raised spa, 3 stone scupers
    Jandy 60 SqFt DE, Jandy PDA PS6, Jandy JXi400 heater, Jandy 2.0 EPump w/SVRS
    A&A Manufacturing ICS w/G4 venturi heads
    2 incandescent lights in pool, 1 in spa.
