Thread: clogged skimmer line
    Jun 2013
    Irmo, SC
    37
    We started having trouble with our pool and called a repair person. She said the pump wasn't priming at all and we needed to replace it. After she replaced it, she discovered that the skimmmer line was also clogged. She tried to unclog it (I think with a hose) and couldn't get it. She didn't have any muriatic acid, but gave me some instructions to use if I wanted to get some and try it myself so it wouldn't be another service call. Anyway, she said to pour the muriatic acid down a pipe she had attached to the suction line inside the skimmer area. She said to do this with the pump off and then turn it on and backwash. I did, and there is still a lot of air in the line, so the clog is still there. Before I get more muriatic acid, I thought I'd see if anybody has advice on here to unclog it.
    12500; sand; IG; vinyl; Tf-100 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: clogged skimmer line
    Never had to that before, but I think the first thing I would try is a plumber's snake.
    38,275
    Forget the acid, that like a horrible idea
    Try a drain king from the pump back toward to skimmer.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    You can try a shop vac set to suck water and try to seal the hose over the opening in the bottom of the skimmer and try to suck it back out.
    Using a snake might be the best way. No clue why she would have suggested muratic acid.
    Solar Blanket, Well Water, Borax Added. 68
