Thread: salt question
    Mar 2015
    South Texas
    411
    salt question
    Please forgive my ignorance, I have been doing a lot of reading and just have a quick question. From what I read, once you get your salt level where you want it (2800-3800 or so), you really shouldn't have to add salt unless for some reason you lose pool water out of the pool (leak, splashing, backwashing, etc.). Is that correct?
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    38,251
    Re: salt question
    That is correct.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: salt question
    No hauling salt for you !! You're good.
    Solar Blanket, Well Water, Borax Added. 68
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: salt question
    Yes, rainwater overflow is the main reason for salt loss for us. You will not lose any salt to evaporation.
    May 2013
    mid-TN
    102
    Re: salt question
    check with your salt water generator. mine low is at 2100 and at 3400 it will turn off to
    protect it self. as for adding salt I might put two 40 bags in during a summer if I start
    at 3200. occasionally you loose some during a backflush or running your vacuuming to
    waste.
    18X36 Grecian 24400 est., pacfab sand Triton II, 1.5hp AOSmith, clormatic 2
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: salt question
    Also you don't need "pool" salt, regular solar salt for water softeners is fine. Instead of dissolving in 10 minutes it may take 30, depending on water temperature. Save the money, upgrade your beer.
