Results 1 to 9 of 9
Thread: Why is my ph always high?
    Themacdadt's Avatar
    Sep 2013
    Cocoa, fl
    112
    Is there something wrong with my chemical balance? All chemicals are in range but for some reason I am always having to add acid to lower my ph. I use almost a half gallon a week. Everything else stays fine. But like I said I'm averaging 1-2 cups a day of acid. Is this normal beacause of the swg?
    Any in put would be appreciated
    Thanks Todd.
    15,000 gal. In ground, sand textured with beach area, spa located in beach area with spillover equal to pool level.Rock waterfall with 4 foot drop.Hayward goldline aquaplus automation all wireless remote.T 15 cell,Propane heater,Super 2 for pool/spa,Super 2 for waterfall.Cartridge filter and solar panels.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Why is my ph always high?
    That is very normal and it happens faster in newer pools. Still, your makeup water probably has higher pH & total alkalinity (TA), so this plays a large role in pH rise.
    Other factors like the SWG do contribute as well, but this is the basic reason. As the TA works down, the rise will slow, but you have to work on it to reduce the TA. There is an article in Pool School on how to do that. Having it lower in a salt pool is a prudent thing to do, largely for the reason you inquire about.
    Essential Links:
    Jun 2011
    Long Beach, CA
    2,790
    Post your full test results and we will see if anything can be adjusted to reduce the acid usage.
    jojoman's Avatar
    Jun 2014
    Mandeville,La
    185
    Is it a new pool or a replastered pool, both can rise ph for about a year or so. From what i read the SWG can slowly rise ph too. I'm in the same boat, with 1/2 gallon of acid every week but down from a gallon a week after pool pool was finished back in September. Also, are you using a good test kit to get your readings? I found test strips were okay at ph reading but a good test kit will pen it down better.
    12K gal, custom flipped kidney bean with spillover spa. All Pentair equipment, Whisperflo 1 1/2 HP, 400K BTU heater, Intellichlor IC 40 SWG, CCP-320 Cartridge filters, Kreepy Krauly pool cleaner with bootster pump, QuartzScapes in Aruba Sky blue, LED lights and travertine tiles for decking and stones on rear edge for landscaping. TF-100 test kit w/ SpeedStir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Also, running waterfalls, spillovers, laminar jets, etc will increase your ph.
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    Quote Originally Posted by pooldv View Post
    I see the OP signature says 4 FOOT DROP on waterfall. cool! but you might be getting a TINY bit of aeration off that sucker.
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
    Themacdadt's Avatar
    Sep 2013
    Cocoa, fl
    112
    Quote Originally Posted by ping View Post
    Fc 4
    Cc .5
    Ta 75
    Ch 330
    Ph 8.2
    Cya 65
    Hardly ever run waterfall, spillover on spa is 1 inch, only spilling over 4 hours a day when pump is running and its a smooth transaction.
    Not re plastered, pool is approx. 8 years old. SWG on 40%
    Thanks Todd.
    Letting the TA go down to 60 will certainly help as would running the spillover less of the time. If that isn't enough, adding borates and lowering the TA a little further should do it.
    Mar 2015
    Sydney, australia
    21
    My pool has an auto doser for the acid which keeps the PH pretty well exactly at 7.4. This is connected to a 15l (4 Gallon) drum which lasts about 8 weeks - so I am using the same amount. I also have a SWG and the pool is only small (8000 gallons).
    32,000 litre in-ground painted concrete pool
    Zodiac Tri-Mid +ph SWG
    Solar pool heating
    Taylor K-2006 test kit
    In Sydney, Australia
