Results 1 to 9 of 9
Thread: Post SLAM Question
    May 2014
    Las Vegas NV
    45
    Post SLAM Question
    Hello,
    I just finished the SLAM procedures and wanted to throw my pool cover on that's been sitting on a reel with a plastic cover over it all winter (Vegas winter). Is this a bad idea? Don't want to do the SLAM procedures again.
    Thanks in advance!
    9700 gallon outdoor in-ground 11x26' plaster pool; Pentair Intelliflo Variable Speed pump; Pentair Clean and Clear Plus cartridge filter;
    Pentair MasterTemp 400 natural gas heater; 2-wheel "The Pool Cleaner"
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Post SLAM Question
    No, put it on if you like. Just keep up with your chemistry from here out and you'll be fine. No worries at all with that.
    Essential Links:
    May 2014
    Las Vegas NV
    45
    Thanks!
    May 2014
    Las Vegas NV
    45
    Now that I'm done with SLAM procedures can an I adjust Ph or do I have to wait until chlorine levels come down to normal levels?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Fc need to be below 10.
    Smykowski's Avatar
    Sep 2011
    3,065
    Wait until FC is below 10, then adjust pH.
    May 2014
    Las Vegas NV
    45
    I have 2 questions regarding testing ...
    1. When filling up the testing container is the water supposed to be on the line, just above it or just below it?
    2. When adding daily chlorine we want to add just enough to be at our target by the end of the next day correct?
    1) The surface of the water will be curved. That curve is called a meniscus. The bottom of the meniscus should be at the line.
    2) Almost. You want to raise the FC level to whatever level keeps you at or preferably just a little above the minimum FC level 24 hours later. The target number we give is a guess at what that level will be. But every pool is a little different, so your personal target is likely to be a little different than our "approximate" target level.
    May 2014
    Las Vegas NV
    45
    Thanks a million!
