Page 1 of 3 123 LastLast
Results 1 to 20 of 56
Thread: Algae
    Nov 2014
    Dade City, Florida
    94
    Algae
    New pool owner trying to figure out how I got algae in my pool. I do have the TF-100 test kit. My numbers: Chlorine 1, PH 7.2, FC 12.5, CC 3, CH 175, TA 130, CYA 0. 15,700 gallon pool, temp is 78. Does it need slamming?What should I do?
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Algae
    If you let FC get too low, that would allow algae to gain a foothold. Could have been transferred by a dirty cover, toys, etc.
    No matter how it got there, if you see algae, you need to SLAM it. CC >0.5 also is an indication you need to SLAM.
    How come your CYA is at zero?
    Nov 2014
    Dade City, Florida
    94
    Re: Algae
    I really don't know why the CYA is at zero. Just added about 2 lbs of stabilizer in a sock and put it in the skimmer. A little confused about the Chlorine /CYA chart. How do I read the last column? How many gallons of bleach do I need to add?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Algae
    Hi Dave!
    There is one way, and only one way you get Algae. Improper/lack of free Chlorine. It is truly that simple.
    You'll need to SLAM your pool now, and the link for how to do that is in my signature line. In your sig line, please add your pool info so that we can help you. Not knowing your pool size, no one can say how much Chlorine you need. That said, it would be good for you to spend some more time in Pool School. Start with the ABCs and work up from there. This is the most important thing you can do for the long haul and up front.
    Your Cya has not had time to dissolve and disperse throughout the pool yet.
    Essential Links:
    jojoman's Avatar
    Jun 2014
    Mandeville,La
    185
    Re: Algae
    CYA can take up to a week to show up. So don't over do it by throwing more in unless it has been more than a week from last time.
    12K gal, custom flipped kidney bean with spillover spa. All Pentair equipment, Whisperflo 1 1/2 HP, 400K BTU heater, Intellichlor IC 40 SWG, CCP-320 Cartridge filters, Kreepy Krauly pool cleaner with bootster pump, QuartzScapes in Aruba Sky blue, LED lights and travertine tiles for decking and stones on rear edge for landscaping. TF-100 test kit w/ SpeedStir
    Nov 2014
    Dade City, Florida
    94
    Re: Algae
    Quote Originally Posted by Patrick_B View Post
    Hi Dave!
    How do I add my pool info to my signature line? Thanks !
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Algae
    Please add your pool details to your signature as described HERE as it will help us help you.
    http://www.troublefreepool.com/conte...efore-you-post
    Nov 2014
    Dade City, Florida
    94
    Re: Algae
    Quote Originally Posted by pooldv View Post
    I think I found it.
    18X33 Sharkline Morada Pool 15,700 gallons, Pentair Sand Dollar Filter SD-60, 1.5HP Hayward Pump, AquaLuminator Light, Solar Blanket & Reel and two 4' by 20' Solar Panels. TF-100.
    DFW, TX
    24,497
    Re: Algae
    Quote Originally Posted by Dave2590 View Post
    I think I found it.
    yep good to go!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Algae
    Thanks Pooldv!
    Essential Links:
    Nov 2014
    Dade City, Florida
    94
    Re: Algae
    Quote Originally Posted by jojoman View Post
    I started at zero and Pool Math told me to add 84 oz by weight of stabilizer. Thats alot !
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Algae
    Just five pounds. Not really that much.
    Essential Links:
    Nov 2014
    Dade City, Florida
    94
    Re: Algae
    Ok good, thanks Patrick. But I'm still not sure how much chlorine I need to add now. I did add 2 gallons of bleach. Is that enough given my numbers?
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Algae
    From using pool math, 15,700 and 84oz of stabilizer would put you at 40 so use 40 for your CYA presently and don't bother to retest for a week. If there's still stabilizer in that sock you can knead it and it will dissolve quicker. You want to wait until it's all dissolved from the sock and then a week to retest.
    With algae you'll need to SLAM and you want to maintain the FC at 16 as best you can. Test and add often as letting it fall and bringing it back up doesn't work as well as maintaining it.
    You need to use Pool Math at the top of every page to figure out the correct amount of chlorine to add. You need to know the strength of the chlorine you're adding.
    If you were at zero FC you would have needed to add a little over 5gals of 6% to reach that 16ppm FC level you need to maintain.
    Solar Blanket, Well Water, Borax Added. 68
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Algae
    Once you get the algae gone and have completed the SLAM you will need to hold a minimum of 3 and should try to maintain 5ppm FC if you keep the CYA at 40. Below 3ppm and you run the risk of the algae coming back.
    When doing the SLAM remember to brush the pool often and scrub anything in the pool. Take the ladder out and scrub it. Check behind the skimmer door for "green".
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Algae
    No, go ahead with two more, and test tonight. It's a little bit much, but it will be down before long if you are pretty green. Make sure you get another test and addition made before bed if you need it. If this was my pool, this is exactly what I would do.
    Essential Links:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Algae
    Dave, have you tried Pool Math in the link up at the top of the forum? It will tell your dosage needs. If you have a question on it, post back and we can help.
    Essential Links:
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Algae
    PoolMath, link in upper left of each page. http://www.troublefreepool.com/calc.html
    Nov 2014
    Dade City, Florida
    94
    Re: Algae
    Yes I've tried Pool Math. Didn't see these last few posts yesterday so I only put the two gallons of bleach in and the stabilizer is in process in the skimmer so the CYA will come up over the next week.. Since the CYA is near zero I think the 2 gallons was enough yesterday. Will test again this morning. Pool Math is telling me to add 71oz of Borax and 198 oz of calcium chloride. Had rain yesterday and cold front came through last night. 49 degrees now so pool water temp has dropped some. Water is still pretty clear. There is not alot of algae so maybe I'm getting it early.
  20. Back To Top    #20
    Nov 2014
    Dade City, Florida
    94
    Re: Algae
    Thanks guys. Forgot to mention FC was at 16 last night. I will keep it there.
