Thread: Quick question about the grill used for your ODK
    Mar 2015
    Savannah, TX
    10
    I am going to doing an ODK this year and I was planning using my current Weber grill. Has anyone used an existing outdoor grill and just taken it apart then installed it in their ODK? Also, where should the propane tank be? In my current grill it sits underneath the grill, can I do that with a ODK?
    Thanks.
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    Re: Quick question about the grill used for your ODK
    There are several styles of grills you can use in an ODK build. For me, I went with a Weber Summit S660 (natural gas). It's just a normal rolling grill. I had a niche built in the counter/cabinet to fit it. It's still on wheels and I can roll it out if I need to get in behind it to clean or anything. It also came with spacer panels so you can make it look more built-in. The only thing I would say to watch out for is code issues related to venting. If you turn a grill into a "built-in", you may need to have vent panels installed in the base to make sure you don't ever end up with a gas build up under the cabinet. If you go to the link in my signature for my ODK build, you can see the grill near the end of page 1. There is a base panel that came with the grill that I need to install to cover the wheels which is obvious in the photos.
    Good luck.
    plat.
    Modern Geometric-ish Social Pool (4'-5'-4') ~13' x 47'. Sun shelf. Perimeter overflow spa. RiverFlow Swimjet. Dog ramp. "Bubble Lounge"
    Link to my patio build, completed 2013
    Link to my pool build, Aug '15 - Sep '16
    Jan 2013
    Friendswood, TX
    320
    You can. However it may not look as finished depending on how you are able to take it apart.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
