Thread: What to do with my pump?
    98xc600's Avatar
    Jul 2007
    Southern MN
    148
    Over the weekend my filter developed a crack. It's only 1.5 years old. I've somewhat expected it would happen because every time the pump would start you could see the top of the filter flex about 1/4 of an inch. Then when I would turn on the solar heater it would flex another 1/8.The psi has always stayed the same 11psi no heater 20psi with the heater.
    So with the info I read on here I had no problem picking out a new filter. I went with a Hayward S220T sand filter. It has a flow rating of 52gpm 80% of that would be 41.6gpm. At that rate I could turn my pools water over in about 6 hrs give or take.
    Now the problem.
    I have no info on the pump that's there now. All I know is that it's a Waterway 48 frame center discharge and that's it. How do I know if this pump was way to big for the filter and caused this to happen? Would this pump cause the same thing to happen with the new filter? Can anyone shed some light on this for me.
    16' by 32' cornelius AG vinyl liner, 6' deep end, 14500 gal.
    Hayward 250 Lb sand filter
    Hayward 40 GPM pump
    2-2' by 20' sun grabber solar heater.
    4 gal Liquidator. BBB
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: What to do with my pump?
    Can you read the label on the pump motor? What is the Horsepower (HP) and Service Factor (SF) of the pump? Any model number or other information?
    Mark
    98xc600's Avatar
    Jul 2007
    Southern MN
    148
    There is nothing for HP or SF. The model # for the motor is SP-15--1N11CC.
    Hayward 40 GPM pump
    mas985's Avatar
    Pleasanton, CA
    11,737
    I did a quick search and couldn't find anything on that pump but maybe someone else knows of it.
    Anyway, I wanted to point out that it is fairly typical for a filter to expand when the pump turns on. Mine does and I have an oversized filter on a small pump. So that alone does not indicate that your pump is too big. If it was matched set to begin with, then it was probably ok for that size filter although some manufactures tend to oversize the pump in those combo sets.
    How old was the filter when it failed?
    Mark
    98xc600's Avatar
    Jul 2007
    Southern MN
    148
    I did some searches as well and I got the same results as you. The filter was only a 1.5 years old.
    Hayward 40 GPM pump
