Results 1 to 10 of 10
Thread: Intex 635T replacement suggestions
    May 2013
    Lacombe, LA
    19
    Hey gang,
    My pump finally kicked the bucket after nearly two years. It was working fine, but the impeller messed up. As I've found on the forums, no replacement of parts are available.
    I use a saltwater system in conjuction with this pump, just wondering if you guys had suggestions for another model I might look at. I'm not opposed to getting another, just seeing if there's been anything that you stand by. Thanks!
    5,500 Gallons
    AG - Intex 16x48 Ultra Frame
    Intex 1200 GPH Krystal Clear Sand Filter Pump 28643EG
    Saltwater System
    Install - 05/2013
    Re: Intex 635T replacement suggestions
    It is definitely worth considering one of the Intex sand filter systems. They are a little more expensive, but well worth it.
    May 2013
    Lacombe, LA
    19
    Quote Originally Posted by JasonLion View Post
    Two follow up questions Jason (and I appreciate you answering)....do they use filter cartridges (the 635 eats through them), and does this allow for a better vacuuming using this pump?
    5,500 Gallons
    Saltwater System
    Install - 05/2013
    The sand filters use a bed of sand instead of cartridges. They get backwashed, which uses up a little water, instead of replacing the cartridge. All of them have a larger pump than the 635T, so any of them will be better at vacuuming than a 635T.
    May 2013
    Lacombe, LA
    19
    I'll definitely check this out! It sounds like this would save me a lot of time. I love the saltwater system, definitely think that's a must have for any of the AGPs.
    Maybe another thread for this, but any vacuum solutions you'd suggest?
    5,500 Gallons
    Saltwater System
    Install - 05/2013
    May 2013
    Lacombe, LA
    19
    Also, may seem like a dumb question, but I'd assume this would keep the pool much cleaner, right? Living in South Louisiana, get all sorts of debris, pollen, and etc in my pool currently.
    5,500 Gallons
    Saltwater System
    Install - 05/2013
    Yes, much cleaner.
    With the smaller pump your only real choice is the Intex vacuum. But with the somewhat larger pump in the sand filter systems you have the option of going to a convention vacuum head, though you will need to find the correct hose adapter to convert from Intex sizes to non-intex sizes.
    May 2013
    Lacombe, LA
    19
    Yes, much cleaner.
    Jason, just ordered an Intex 28643EG 1200 GPH Sand Filter. I look forward to using this with the salt system, any pointers for it when it comes in?
    5,500 Gallons
    Saltwater System
    Install - 05/2013
    It is very straightforward to setup, you shouldn't have any problems.
    May 2013
    Lacombe, LA
    19
    I haven't doctored up the setup yet Jason, but wanted to share. Had a minor issue with a leak, but that was due to the O-Ring, and then I forgot to rinse and backwash. Other than that, DRAMATIC difference. Gonna post over some results on another thread to get some help there! Just wanted to say thanks!
    5,500 Gallons
    Saltwater System
    Install - 05/2013
