Thread: What type of pump should I get
    Mar 2015
    Las Vegas
    2
    Hi all,
    I've read this forum for some help on other issues so I'd like the input on this on.
    I currently have an old Emerson 1081 pump, 2HP pump. Not sure how old it is but it's at least from 2007 and most likely earlier. I've been looking into getting something that is more energy efficient but am torn on what to get. I was considering a variable speed pump when I came across people talking about 2 speed pumps having a somewhat similar outcome at a lower price. My question is, should I go for the variable speed, since NV Power is currently giving a $250 rebate or just go for the 2 speed? I figure both should give me a good amount of savings over what I currently have but not sure which is better. Power rates here are $.124/kWh.
    Thanks for any input
    P.S.I am unsure of how long the rebate will last and I'm not quite ready at this moment to pull the trigger on replacing the pump.
    P.P.S
    I'd like to install this myself. I'm somewhat mechanically inclined and saw a video that didn't look too difficult. Should I attempt this or break don and pay someone to do it?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    Re: What type of pump should I get
    Hi and welcome to TFP.
    Choosing the right pump is dependent upon a few factors. Such as size of your pool, do you have any water features or not, is the pump location higher than the water level or not. If so, how much.
    If you could fill in your signature, and provide some info about your pool, it would help us help you.
    http://www.troublefreepool.com/conte...efore-you-post
    Divin Dave,
    At your electrical rates, a two speed is almost certain to have a lower total lifetime cost compared to a variable speed.
    If you have a spa or large water feature you will probably want to stick with a 2 HP but switch to two speed. If you just have a pool and nothing else, switching to a 1 HP two speed has several advantages.
    Mar 2015
    Las Vegas
    2
    Updated the signature so it'll help in the future.
    The pump is ground level about 10' from the pool. The spa spills over into the pool. I do have a water feature but it runs on a separate pump.
    ~13,000 Gal, IG, plaster, built in 2000
    Sta-rite S8M150 cartridge filter
    Emerson 1081 Single speed 2HP motor
    Spillover spa and attached water fountain w/ separate pump
    If the main pump runs the spa jets, you will want a 2 HP two speed of about the same SFHP (Service Factor times Horse Power) as your current pump. That will keep the strength of the spa jets about the same.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    If it's model EUST1202 it should be a service factor of 1.0
    That model number and SF rating should be on the motors label.
    Solar Blanket, Well Water, Borax Added. 76
