Results 1 to 8 of 8
Thread: SWG recommendation
    SWG recommendation
    We are replacing our compupool SWG and would love any new info or recommendations on either the newer Compupool or any other recommendations on the best SWG to get. Or any negatives we should know now...Thanks
    We have a 20x40 33000 gal vinyl liner pool
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: SWG recommendation
    Which version did you have? They've come out with a new versions Infinity/CPX. I have a CPX-36 that replaced a CPSC-48. So far so good.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    I would recommend a Circupool Si-60 or Si-60+ for your size pool. The Compupool CPX-36 or 48 may be a bit undersized for a 33,000 gallon pool. I have the Circupool Si-40.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    I had a cpsc-36 which was a model that had problems with the circuit board.. they did replace it, but we kept having problems and finally it just didnt work anymore. Compupool suggested we buy the newer version cpx. Is the infinity the same as the CPX? or another new one?
    I have read they are better now, so hoping to just get a new updated version.. I am realizing the 36 was way too small for our pool which makes sense since we did have to run it a lot more than I thought it needed it, and even add bleach from time to time with a heavy load.. I have loved the ease of the SWG!!
    Is the Circupool made by the same company as compupool? somewhere I thought I read this.. Or is it just a similar product?
    what is the difference between the Si60 and the SI60+ ??
    20 x 40 rectangle vinyl liner 33000 gal.
    Apr 2011
    Murrieta, CA
    2,360
    Hello the CPX and Infinity series are very similar. They both use the same transformer, but have a different interface/software. I think the CPX has a 3 way cell and the Infinity has a 2 way cell. They are rated the same outputs. You'd definitely want the largest cell they offer (Infinity-60/CPX 48)
    They have a new US website: http://www.compupoolhelp.com/index.html
    where would I find who sells the Compupool Infinity to get a price? I only found someone carrying the CPX system.. Anyone else love their system or have any input, good or Bad? Love to hear what others have and like..or have trouble with.. Thanks!
    Apr 2011
    Murrieta, CA
    2,360
    Why not contact Compupool directly: http://www.compupoolhelp.com/contact-us.html
