Thread: Effect of light on chlorine degradation
    May 2011
    Granite Bay, CA (Sacramento area)
    99
    Finally got my Stenner pump. It's hooked up to a 15 gallon drum I got free from a carwash. The drum is tranlucent and I have it under our deck, so it gets shade most of the day, but might get some filtered morning sun.
    I've been using liquid chlorine, and I understand that higher concentrations of bleach degrade faster than lower concentrations due to heat. But what about light?
    18,000 gallon IG gunite freeform pool
    Intelliflo VS pump; Hayward SwimClear-C4030 425 sq ft filter; 4x suction PoolCleaner
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: Effect of light on chlorine degradation
    Sun light burns up the chlorine in a pool--------so why not stored in a translucent drum? Put a strip of tape on it, spray paint it, remove tape for a visual. Or just cover it.
    Mar 2007
    San Rafael, CA USA
    12,082
    You want the container to be opaque to UV light. Otherwise the chlorine in the container will degrade quickly in sunlight.
    May 2011
    99
    Thanks guys. Does it matter if it's not being hit by direct sunlight? Does scattered light (i.e. sitting in shade) still affect it?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Not as much, but if you can throw over an old sheet or anything that wouldn't bug you, it would be better.
    Essential Links:
