Thread: #3 rebar vs. #4?
    Nov 2014
    Dallas Texas
    165
    #3 rebar vs. #4?
    Obviously one is thicker than the other. I assume that some use #3 to save funds. How important is the difference?
    30,395
    Re: #3 rebar vs. #4?
    #3 rebar is 3/8" diameter....#4 is 1/2" diameter
    For pools, 3/8 is likely just fine but that's a general statement.
    It all depends on what you are doing. In almost all cases it is a structural issue. Areas that need to carry heavier loads get thicker rebar.
    Mar 2015
    Pearland, Texas
    11
    It depends on a lot of things. How wide a span the rebar is bridging, how thick the concrete is, how closely the rebar is spaced, and even what type of gunnite is used.
    If you are really worried about it, get an engineer to take a look. The cost shouldn't be more than a couple hundred dollars and the peace of mind is worth it IMHO.
    Feb 2015
    Frisco, TX
    21
    I know in the DFW area PB always recommend to go with the #4. When I was getting quotes all of them recommended to do the #4.
    Jul 2013
    Weatherford, Tx
    7
    First, I have never built a pool so I'd like you to know that up front. I seem to remember, generally, #3 on 8in centers, or #4 on 10in centers. Most with 4 sticks of #4 rebar for the bond beam. Of course, it all depends on length, depth, soil conditions, etc. I have a few questions I am about to start on another thread on rebar as well. May give you some more info if I get some responses. Good luck.
    17x40, 3.5 to 9'. Apx 32k gallons. Apx 20 feet of 0 to 36" freestanding wall, 12' tanning ledge, 3hp Pentair intelliflo, 3/4 booster pump, Pentair, 60DE filter, 2 intellibright lights, 2 skimmers, 5? Returns, pebble sheen, ? on Coping, and tile. Fastlane
