Thread: Pump power
    Aug 2013
    Mcallen, TX
    39
    Pump power
    I have an 18k gallon pool and have a 1 hp pump feeding from a main drain and two skimmers. I was wondering if 1 hp enough. I have a waterfall that is about 6 ft high with a 2 hp pump, does anyone think maybe when they installed the equipment they switched the pumps? I ask because I notice that I have to play around with the Valves to get the right suction at one end of the skimmer since there isn't enough for both skimmers and main drain.
    JR
    17k gallon pool, pentair whisperflo pump 1hp, Pentair FNS Plus 36, SWG Hayward Turbo Cell 15 40,000g, blue quartz with pebble finish landings/bench, ultra pure water cleaner.
    Re: Pump power
    A 1 HP pump should be more than enough for that pool. Normally I recommend using a two speed 1 HP pump on low speed in that situation. Meanwhile, it is very common to need a large pump for a waterfall.
    What do you mean by "there isn't enough for both skimmers and main drain"?
    Aug 2013
    Mcallen, TX
    39
    Re: Pump power
    Thanks for the reply! If my valves for both skimmers and main drain were all open I would get almost no flow on the skimmer. So what I do is have one skimmer fully open, and the main drain and other skimmer partially closed. I notice I get a lot of build up of debri on top if both skimmers are fully open. I usually open skimmer on down wind.
    38,532
    Re: Pump power
    I would leave the floor nearly closed off to get better skimming.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Pump power
    I agree with JB. MDs are overrated and not really required. You are much better off taking flow from just the skimmers.
    Mark
