Thread: Recommended levels for pool with lots of leaves falling in it?
    Mar 2015
    Plano, TX
    18
    My pool has 3 trees that hang over it, and as a result lots of leaves fall in. Does this increase my FC demand due to all of the organic matter? If so, should I aim for slightly higher FC levels, or just stick with the normal levels?
    1982 built 15K? gallon IG gunite/plaster, DE filter, Pentair Challenger 1.5HP pump, Polaris 280, Pentair LA01N booster pump, 3-8' with diving board, K-2006 test kit
    38,371
    Re: Recommended levels for pool with lots of leaves falling in it?
    The key is to never let the FC level fall below the minimum for your CYA. Up to you to determine how high you need to shoot for each day ... you might need a little higher, but I would not think much.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Your minimum FC level remains the same no matter how many trees are dropping debris in. The amount of bleach needed will vary with the organic load. You'll have to discover by trial-and-error just what the demand is for your pool. If you read 3 and your minimum is 5, and you add enough bleach to get to 5 and the next day you're at 1, you need to target your minimum (5) plus your loss (4) and raise FC to 9 each day. Or whatever your particular numbers are. That depends entirely on your CYA level and your daily losses. Also remember that once people start swimming, your chlorine demand will go up.
    The sooner the leaves are removed, the less chlorine is used up trying to oxidize them. But also remember that leaves caught in the skimmer and strainer baskets are still in your pool water, even if they're not on the floor of the pool, so empty them often.
    Nov 2013
    Phoenix, AZ
    15
    This is a very important point about skimmer baskets. Not emphasized enough. Especially during SLAM
    50,000 gallon, IG, pebble, Triton II sand filter, Hayward EchoStar VS pump, Dolphin M5
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,777
    Ward, my pool is in the same kind of setting with all manner of debris. While it is truly trial and error, and also depends on sun and temp, I generally find that I'll use about 2 ppm daily - your mileage may vary. I generally bump up my "min." In my mind due to the debris, eg. Min 4.5 becomes 5 in my mind, so by dosing to 7 each day with a generous min. I never even cloud up.
    The beauty of the test kit though, is you'll never have to wonder. Keep a little log on a notepad or your phone and you'll pretty quickly see trends and establish a baseline, assuming your cya is stable and you aren't adding any. Which in turn is the beauty of using liquid chlorine/bleach over products with cya...your target min. also remains stable and therefore more predictable. These two lynchpins of TFP are what make TFP methods trouble-free
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Quote Originally Posted by Swampwoman View Post
    Great advice and that's what I've been doing. Works really well.
    Dolphin E10 Cleaning Robot.
