Thread: Cheap option for cl2 addition. SWG, stenner, and liquidator too much.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Alright, here's the story. I need a replacement SWG system. I don't have/don't want to spend $1000 on a SWG at this time. A stenner is right up my alley, but more than I want to spend on such a simple device. The liquidator seems cool, and I found in on sale for $120. Not bad, but if I have to compare the price of bleach vs an SWG, the equipment needs to be nearly $0 to even make sense. Based on my crude math, it would take three years of bleach to equal the price of an SWG. If I don't want to add it by hand, it doesn't need to cost much to add it before the SWG pulls way ahead $ wise. I've seen where people have used the "buttons" to limit flow of bleach to the suction side of their pump. I've also seen people use needle valves to do the same thing. Has anyone used a water pump, like the liquidator apparently uses, to inject chlorine? I'm thinking about taking water from the pressure side of the system, after the filter, running it through the jet, and back to the suction of the pump. This is the device I'm thinking about. It's polypropylene which has decent resistance to sodium hydrochloride up until 140 degrees. http://www.amazon.com/gp/aw/d/B004AH...sZL&ref=plSrch
    What say ye?
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Re: Cheap option for cl2 addition. SWG, stenner, and liquidator too much.
    Venturi injectors will draw a chemical into the plumbing, but the injection rate will vary too much to be useful solution. In the long run there will usually also be clogging problems.
    There are other brands of peristaltic metering pumps besides Stenner. Some of them are good enough to be usable and much less expensive.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    In my setup, the only variable should be whether the booster pump is running. Maybe a dirty filter dropping the pressure could be an issue. I was wondering how the salts precipitating out would cause clogging. I have an 1/8" solenoid valve from another project that I could use instead of cutting back the flow with a needle valve. Not sure if that would alleviate the plugging or not. Are the other pumps you mention the little 6 & 12 v ones on eBay, or do you have others in mind?
    Way way more will affect the injection rate aside from the booster pump being on. The filter getting dirty makes a large difference. The amount of bleach in the supply tank will make a difference. The temperature will make a difference, and on and on and on.
    Search for "peristaltic metering pumps" on e-bay. There are many many choices. Some of the aquarium systems are fairly well made.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I hadn't thought about the pressure difference as the tank level drops, or the viscosity changing with temperature. I guess that's why the liquidator maintains a constant liquid level via the float valve? Sounds like this method has been disproven. Now to find a peristaltic pump for under $40. eBay purchases lack the reviews that Amazon has. That's the only drawback there. I'll check them all out and see what the best deal is.
