Results 1 to 7 of 7
Thread: New SWCG installed, do i add solar salt to water?
    Feb 2014
    Upstate, NY
    390
    I just installed a SWCG in my IG pool. Cover is still on and the SWCG has not been turned on yet. Do I have to add solar salt to the water initially after I open the pool up ??? Or should I run the SWCG first when I open the pool up and see what the numbers are first ??
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,652
    Re: New SWCG installed, do i add solar salt to water?
    At this point, I'd just forget you have the SWG at the moment. Open, circulate and balance as usual and check for any problems. THEN add salt, circulate for 24 hours--make sure your cya is 70 to 80------then fire it up and dial it in.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    what woody says.
    Divin Dave,
    38,475
    How "old" is the water in the pool? If it is a new fill, the salt level should be pretty low. If it is older, you could have salt already up around 1000ppm.
    I agree I would open and balance as usual. Then add about 2000ppm of salt, let that circulate for a day and see what the SWG thinks about the salt level. Then add more salt if needed. Always have the SWG off for 24 hours after adding salt.
    Feb 2014
    Upstate, NY
    390
    Thank you guys. Wow, I didn't know about turning off the SWG 24 hours after adding salt. The water is a year old now. Last I checked (Sept 2014) the CYA was at 100.
    38,475
    Well, I hope that the CYA dropped some over the winter and that is a bit on the high side.
    Feb 2014
    Upstate, NY
    390
    Yes JB I knew it was on the high side. Going to drain some water out when the weather permits. Thx
