Thread: Worn down weights from a Kreepy Krauly -- are they lead?
    Mar 2015
    hayward, ca
    3
    Hi all, I'm a new pool owner for a few months and this site has been wonderfully helpful. I'm in the process of upgrading a Kreepy Krauly (with a Poolvergnuegen 4X!). Upon dismantling the Krauly, I noticed this weight bar had several of its weights worn through the plastic enclosure. These feel like they are made out of lead (but I would hope not). Should I be concerned about having lead contamination in my pool now?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Worn down weights from a Kreepy Krauly -- are they lead?
    Welcome to TFP andrewsan!
    I can't tell from the photo if they are, and I've never owned one of these. Have you scratched them with something or done something else to determine if they are Lead? It looks a little dark for being Lead, but I'm guessing from here.
    Essential Links:
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    It sure looks like lead to me.
    Support the site
    Mar 2015
    hayward, ca
    3
    They do certainly feel like lead (soft and scratchable). Again I'm new to pool ownership, so I'm not exactly sure how this ballast bar is supposed to function with the cleaner head -- clearly it was scraping around the walls/floor of the pool. I will be contacting Pentair to see if they have a response, and I will be doing a diy water test in the short term.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    A DIY water test for Lead?
    Maybe they are lead, and if so, I guess you'll have to keep replacing the weights before they wear through the skin.
    Seems a potential liability for them in this day and age. I fully appreciate the dangers of Lead, but it's surprising they would still use them with all the hysteria surrounding almost anything made from it these days.
    Essential Links:
    Mar 2015
    hayward, ca
    3
    just FYI, as a follow-up -- i tested the metal with a lead-test stick used for lead paint. it came out positive, so i'm quite convinced that these lead weights have been dragging around my pool for some time. ugh. Check your old Kauly's. Pentair did not respond to my inquiry...
