Results 1 to 12 of 12
Thread: Backwash returning a small amount of flow to return jet.
    Apr 2013
    Memphis
    10
    Good afternoon all.
    I have an odd thing I havent found a thread on yet. On my Hayward sand filter ( S-244T) i am getting this small amount of flow returning to the pool during a backwash. Because I have solid PVC plumbing with unions, I've only checked a few times but I do not believe the multiport is leaking to waste when i am in "filter" mode. I've put in a new spider gasket, seated it with rubber cement (supplied by memphis pool where I bought the gasket) and that did nothing to improve. I went back, they advised I check for cracks and proper seating so i pulled it all apart again and found no cracks and the gasket is in place all the way around and the adhesive is holding it in place. There was a tiny pitted section on my lever assembly where the rotating spring loaded pad engages the rubber spider gasket, so I brought that in and just bought a new entire piece. Just installed it and still, this small amount of flow going back to the pool! What else should I be looking for? I'm so very confused. Thanks!
    Kane
    the flow has some pressure too - as you would assume. I'd say it's volume would be about that of a garden hose that is half or less turned on. Consistent and constant flow.
    Memphis, TN.
    30,000 in ground rectangle Pool
    Salt water converted with Pool Pilot auto Pilot digital
    Hayward S-244T Sand Filter - 3.14 SqFt / 300Lb sand
    Sta Rite Dyna Glas pump - 1HP motor
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Backwash returning a small amount of flow to return jet.
    I've never heard of using rubber cement on an O ring gasket. Just good old pool lube silicon sealant.
    38,521
    I have often seen it suggested to use cement to hold the spider gasket in-place ... and then of course a lube on the upper surface to help the valve spin.
    Of course I am not sure how much that helps ... sure makes it a pain to remove and replace in the future.
    Apr 2013
    Memphis
    10
    Yea, after reading through the forum afterward I wish I hadnt used it - but we have what we have now. It looks and feels seated, are ya'll suggesting this could be the source of the bypass?
    Memphis, TN.
    38,521
    There is really no other way for the water to go. The multi-valve directs all the water, so if you are getting water out 2 of the outlets (to pool and to backwash) it must be something in the valve allowing it to happen.
    Apr 2013
    Memphis
    10
    Absolutely agree Jbizzle.. It has to be in the multiport valve. I'm just curious if i've missed something or didnt check properly or something. again, I appreciate ya'lls input!
    If it helps, I've been looking closer at it again today and disconnected the waste line to observe any flow that would be going through there, and i saw no water going to waste during the filter setting.
    Memphis, TN.
    Mar 2011
    441
    If no water is going to waste, the spider gasket/rotor can still be your problem.
    20X40 30,000 gallon gunite pool
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Good day, can someone give me the exact model number of the valve. If it is a SP714 the gasket is on the puck the goes up and down and is replaced as a whole part and not just the gasket. If it is a 700 series valve it is important that the gasket is glued in with rubber cement or super glue. Also make sure the surface where the gasket is glued is clean. If someone gives me the exact model of the valve I will make sure you have the right gasket.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Apr 2013
    Memphis
    10
    Quote Originally Posted by Hayward Pool View Post
    Thanks for your reply! I can confirm that it is the style that the gasket is not attached to the puck, and has been rubber cemented into the stationary tracks below - So, I guess it is the 700 series? I can go back to the store where I bought the valve body top and ask for the model number, or is there a different way I can find out? The whole filter number is a 244-T if that helps. Thanks again!
    Memphis, TN.
    Oct 2014
    Elizabeth
    426
    If the gasket glues into the body of the valve it should be the old style 710 and not the 714. Take a picture of the valve and post. The label has a model number on top of the valve but sometimes the sun fades that away.
    Hayward Pool Tech
    Apr 2013
    Memphis
    10
    Here we are. Sorry that took so long. It appears it is an aftermarket valve and not a hayward brand??
    Memphis, TN.
    Oct 2014
    Elizabeth
    426
    It could still be a private label valve. I would call the company listed and ask.
    Hayward Pool Tech
