Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: Crack in PVC Elbow Partially in Gunite - Suggestions for Repair?
    Hi all -
    After about a day's worth of digging, I finally found the source of a plumbing leak I've been suspecting for about a month. Check out the attached pics.
    This 3/4" pipe goes to our weeping wall, one of two that feed the water feature. The problem is, the crack is in a 90* elbow that goes right into the gunite after which the pipe then goes vertical. Any suggestions on how I can repair this properly?
    - worst case, I figured I could just cap the pipe and just feed the water feature with just the other pipe and have a somewhat lop-sided water feature
    - is there a PVC glue I can use to close the gap in the crack? The problem is, I don't know how far around the elbow the crack goes. I guess I could chisel some of the gunite below the elbow to find out.
    I'm open to suggestions! Right now, capping it is tops on my list.
    Thanks, all!
    38,548
    Re: Crack in PVC Elbow Partially in Gunite - Suggestions for Repair?
    To repair that properly, I think you would have to chip out the concrete around the pipe.
    Clearly they did not adequately support under the pipe before they buried it.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    PVC Glue isn't going to fix that one unfortunately. I wish I could tell you it could, but I wouldn't try it on my piping.
    Best otpion here is the bad one. If you want it to stay, you'll have to chisel out and replace to do it well.
    Essential Links:
    Thanks, Jason and Patrick. Ugh - I was afraid of that. I guess I can try chiseling and see just how slow it goes (exactly how hard is gunite, anyway ), then worst case I'll just cut and cap the pipe.
    Thanks!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Go do some chiseling and come back with a report on gunite hardness so we'll all know!
    30,432
    There might be a way to fix that reasonably easy.
    When the pipe goes vertical after entering the concrete, where does it go and where does it surface?
    Nice pics. very illustrative.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    If you have an air compressor, try an air hammer. That'll chip it away faster than by hand.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    38,548
    Of course you do not want to get too aggressive and crack the pipe in the concrete too
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hmm, maybe cut...attach tubing to go up through the pipe? Why didn't I think of that?
    Am I close?
    30,432
    Am I close?
    Cha-ching!!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I like it!
    Essential Links:
    Ok, I'm not sure I follow completely, but I'm encouraged and excited!
    Dave - I've attached a couple more pics I took from when the pool was being built. One of the pictures is of the completed weeping wall. The two pipes that feed the water feature terminate in the space right under the stone coping.
    The two other pictures show the plumbing just prior to and after gunite (the offending vertical pipe is the one on the right) so you can see where it comes out.
    So what do we think?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    What we are saying is come back from the elbow a few/several inches, make a cut. Then, lift and break off the section connected to the elbow. It should be easy, being its cracked most of the way round the elbow now. On the end coming from the pump, you install a fitting you can reduce down to a female threaded fitting. Into that you can screw in a tubing fitting that will allow you to connect, and run a smaller diameter piece of tubing up the broken pipe. After the tube is run up, and in place, you could pack the old pipe with silicone sealer or something to make a seal. Since its low flow, and open ended, some variation on this could work.
    Perhaps some details to work out but this is my rough idea on my first cup of coffee this morning.
    PS
    May I assume correctly you've contacted your PB about this, and he's no help? This is clearly a faulty install and entirely their fault. That elbow broke under stress from the ground settling on the pipe run with this installation. Some PBs have a warranty period, but that may be a moot point. I'm simply curious about it.
    Essential Links:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Let Dave weigh in and see if we can hammer down the details.
    Essential Links:
    22,553
    I know that I'm late to the party, but I think I'd try chipping out around the elbow and up the piping a little ways and replace the piping and fittings.
    If you have a air compressor, I'd go to Harbor Freight, etc. and buy a cheap air impact hammer and a set of chisels to chip it out with. You can be pretty gentle with one of those.
    Once I got it chipped out I might even consider repairing it with a piece of heater hose, double clamped. You'd be surprised how long that would last and that would remove the chance of it breaking again because of ground movement.
    P.S. Not the Dave mentioned above.
    Mar 2011
    441
    You will have to chip out the pipe and then install a pipe extender into it then glue a 90 on to the pipe extender.
    20X40 30,000 gallon gunite pool
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I agree the best solution is a full repair, but duraleigh and I were just thinking of how you could get around chipping out the cement.
    Essential Links:
    Thanks, everyone! Normally, I'd be all for the "proper" fix, but since this is a relatively minor part of the plumbing, I'm willing to consider simpler solutions.
    Feb 2014
    Upstate, NY
    390
    I would chip it out. You could rent a chipping gun from Home Depot or your local tool rental place. I think you will be amazed at how well the gun works. Here is just one example of the guns available : http://www6.homedepot.com/tool-truck...14C/index.html
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
  20. Back To Top    #20
    30,432
    I would agree to chipping it out but getting enough concrete removed from the back of the joint above the elbow is likely easier said than done. Give it a try but be prepared to push a tube up through it if the chipping doesn't work.
