Thread: Questions don't get much more basic than this one
    hAltonJones's Avatar
    Sep 2014
    Scottsdale, AZ
    21
    I have a pool cleaner. The filtered water is returned via jets near the surface at the pool corners. But the system also include a spray of water onto the surface (see the picture).
    If it was a sewage pond, the spray would be for aeration. If it were a diving pool, it would be so divers could spot the water surface before entry. But it is neither.
    Howard Jones
    16,000 gal IG
    1 hp Sta-rite
    Scottsdale, AZ
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Questions don't get much more basic than this one
    Appearance. It also will help cool the pool and can lower TA if the pH is low enough.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Probably for evaporative cooling, since you're in Arizona. Nobody likes climbing into bathwater when they were planning a refreshing swim on a hot day.
    jojoman's Avatar
    Jun 2014
    Mandeville,La
    185
    If your water gets in the high 80's to mid 90's you run it some at night when hopefully the temps are in the lower 80's or better. Some of the water's heat will dissipate into the cooler night air. So the water should be a little cooler by morning. My neighbor's pool has them, his PB called them cool jets. Plus as JohnT said, they could also be for appearance and can lower TA if the pH is low enough.
    12K gal, custom flipped kidney bean with spillover spa. All Pentair equipment, Whisperflo 1 1/2 HP, 400K BTU heater, Intellichlor IC 40 SWG, CCP-320 Cartridge filters, Kreepy Krauly pool cleaner with bootster pump, QuartzScapes in Aruba Sky blue, LED lights and travertine tiles for decking and stones on rear edge for landscaping. TF-100 test kit w/ SpeedStir
    Sep 2014
    Scottsdale, AZ
    21
    Thanks for the responses. I guess I should turn it off in the winter months. The water's cool enough.
    Howard Jones
    16,000 gal IG
    1 hp Sta-rite
    Scottsdale, AZ
