Thread: Eyeball diverters?
    Dec 2014
    Riverside California
    482
    Eyeball diverters?
    Hello all. I am in the progress of having my pool re-plastered. Currently, the return lines have no diverters and shoot water straight into the pool. I use a Kreepy Krauly and it tends to be in the deep end (10 ft deep) most of the time. My questions is, would it be worth it to have eyeball diverters installed as part of the re-plaster process in order to be able to adjust the water flow direction to aid the Kreepy in moving up the slope to the shallow end? Now would be the time to install the diverters if at all.
    Thanks
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Eyeball diverters?
    Seperate issues, but I would suggest putting them in to control circulation, absolutely.
    Essential Links:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Amen to what Patrick said.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Yes
    Do it.
    Divin Dave,
