Results 1 to 7 of 7
Thread: Pebble finish only on infinity edge?
    Jaimee's Avatar
    Jun 2014
    Queen Creek /Arizona
    42
    Is it possible to do an infinity edge and waterline without tile? Can you just pebble plaster the whole thing? Yes, I know about hard water and scale, but has anyone done this? Or is it just unwise?
    Building
    4.5K gal in-ground, 876 gal spa in-ground
    negative edge, raised perimeter, 4' depth
    limestone coping, fine pebble plaster with abalone shell, sand filter, propane heater
    My pool build thread: 91265-Jaimee-s-Owner-Builder-Pool-AZ
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pebble finish only on infinity edge?
    Welcome to TFP Jaimee
    Short answer is no. Pool finishes need to be submerged. As long as it stays under water it will be fine, but it can't be exposed.
    Essential Links:
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Quote Originally Posted by Patrick_B View Post
    Probably true but you do see beach entry pools (residential & commercial) and kiddie walk-in pools at commercial locations with pebble finishes.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Nov 2014
    DFW
    38
    One of the PBs I talked to said you could do this for the larger pebbles (PebbleTec), but not the finer ones (Pebblesheen).
    Dallas area | 12' x 29' 10K gallon IG gunite/plaster with 12" raised spa | DE filter, Variable Speed pump, 400K BTU heater, pool cleaner with booster pump, all Pentair equipment | Taylor K-2006 test kit | Excavation 9/16/2014; Pool filled on 10/17/2014
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I'm not sure the size of pebble has much bearing on it, but pebbles would no doubt do better than plain plaster.
    None of these finishes are designed to be permanently exposed. They are designed to fully cure and reside under water.
    Essential Links:
    It really depends on the climate. The hotter and sunnier the climate the less it will work. If you live in a relatively cool/dark part of the world it will be just fine. If you live in Nevada, forget it.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Or Arizona in this instance.
    Essential Links:
