Thread: Years of algae on bottom of pool
    Hello TFP,
    Thanks for the posts on my other post. I know, too long of a post...so I'll
    keep this one short:
    I have about an inch of algae on the bottom of my pool. I am going to order
    a robot (probably the dolphin premier, expensive!) to help keep the pool clean.
    Do you have any suggestions for removing the algae? Should I:
    1) Get a shovel or something and try to remove it with a tool?
    2) Let the robot run and the filter handle the algae trough the skimmer?
    3) Any other suggestions?
    I asked a pool guy to come out and give me an estimate to move my pumping
    station and I told him about the algae. Without seeing my pool, he suggested
    that I might need an acid wash to remove all of the algae. That seems a bit
    extreme to me. And expensive. Any thoughts? Thanks. Mule
    Dark plaster in-ground, 25K gallons, Triton II sand fliter, Teledyne Laars Series 2 ESG heater, Polaris 280 cleaner,
    Circupool RJ45 SWCG, one skimmer doesn't work (any suggestions for snaking this or determining why it doesn't
    work?), using 12mil bubble wrap solar cover, Marquis 660 hot tub using liquid bleach.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Years of algae on bottom of pool
    Without draining the pool, you need to remove as much as possible mechanically. By brushing with a stiff stainless bristle brush. Then SLAM it. You can vacuum and or vacuum to waste as much as you possibly can to remove the bulk before you begin SLAM.
    Also, and most importantly, spend some time in pool school studying the ABCs, defeating Algae, and SLAM.
    The robot is not for removing Algae.
    Essential Links:
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    The Dolphin will not clean up that kind of mess, as Patrick says you will have to do as much as possible mechanically. The Dolphin filters will clog much too fast to make it worthwhile as a clean up tool. It is more of a keep it clean tool.
    SLAM, vacuum & scrape
    Support the site
    The robot was just wishful thinking. I was pretty doubtful. I've been watching the other post
    with jaja. I should have my new pump today: Pentair Superflow 2sp, 1.5 HP. Hopefully, on
    high speed, that will operate my vacuum and I'll send it to waste. that should get me moving in
    the right direction.
    @Patrick: "stiff stainless bristle brush"? Not the fiberglass brush? Is it not strong enough for this?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It might be, try it out. It just sounds bad, but you'll find out soon enough with a little scrubbing.
    Essential Links:
