Results 1 to 10 of 10
Thread: Question about Calcium Chloride
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Calcium Chloride is sometimes used in concrete and can be purchased from Lowes or Home Depot. Is there any reason it cannot be used in pools? It's a whole lot cheaper than the pool store stuff.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Question about Calcium Chloride
    Not sure, but one of the alternatives we mention are certain ice melters.
    Essential Links:
    Calcium chloride is just fine, essentially the same as what the pool stores sell. From what we have seen, it is only available in colder climates, as it is primarily used as an ice melter or to help concrete set properly in cold weather.
    Jan 2013
    Long Island, NY
    184
    Quote Originally Posted by JasonLion View Post
    It's also sold as a product called Damp Rid. Used as a moisture absorber in basements and humid areas. It's more expensive than ice melt, but it will melt ice in a pinch. It's 99% calcium chloride.
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
    Mar 2007
    San Rafael, CA USA
    12,082
    You just want to make sure to use a product that doesn't have metal contaminants such as iron.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Iron contamination is my main concern, but none of the products I've seen list minor contaminants. I suspect (but not sure) that the calcium chloride sold in pool stores is the same as sold by Lowes or Home Depot. But I would hate to be wrong and end up with iron in the pool so I was wondering if anyone had any experience.
    Jun 2013
    SpringHill FL
    415
    You can get it even cheaper at concrete plants. Typically called. Dow Flake. Its roughly 50% the cost than if purchased at lowes or home depot
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Mar 2007
    San Rafael, CA USA
    12,082
    Both DowFlake and Peladow are good choices.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Just a follow up - the pool store sells a 25 lb bag of Dow Flake for $14.95. Lowes sells the identical 25 LB bag for $6.95.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by stev32k View Post
    Nice!
    Silly Leslies....
    Thanks for sharing the good info!
    Essential Links:
