Thread: New house and pool 2 questions
    Apr 2014
    Houston, TX
    19
    I have 2 questions surrounding the new pool in Houston TX .area
    My house is slab on grade and it was finished in January of this year. Is it too soon to dig an inground pool for any settling type reasons?
    The current pool design has a 4 ft deep section within 3 feet of the covered patio slab which is integrated with the rest of the house slab and holds part of the roof structure up the roof line. Is this ok? I dont want to have any warranty issues for the house due to pool distance from the slab.
    thanks.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: New house and pool 2 questions
    I don't think so, but you should check with someone(s) that are truly qualified to answer. Builders, engineers, etc.
    Essential Links:
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Typical structural loads need to be same distance from the pool as the depth in that location. In your example, the 4 ft section needs to be 4 ft minimum from the edge of the pool(in most cases), preferably more.
    Of course there are ways around this but it would more than likely involve adding additional reinforcement to the existing footing and adding additional structural support to the pool wall in the effected areas. Neither are uncommon or overly complicated but will require specific engineering.
    Your pool dig should not change the integrity of the home's foundation (regardless of age) as long as you stay within the parameters mentioned above.
    Patrick is correct though, the structural engineer that provides the engineering for your pool plans would obviously have the final say. I would not rely on any structural advice received from someone on the internet.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
