Thread: Polyquat required with borates?
    I'm just curious if Polyquat is required with borates when closing my inground pool. I don't want to add any more chemicals than necessary.
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Re: Polyquat required with borates?
    If your borates are at 50 ppm then probably not. The Proteam winterinzing kit consists of just the borates and a citric acid based stain remover.
