Thread: New Intex Sand Filter install/Opening Pool
    Jun 2014
    San Jacinto CA
    14
    I have an Intex Ultra Frame 22ft AGP, I purchased an Intex sand filter system for this year.
    Pool is green and dirty from the winter, I have been working to get leaves and debris out, but my concern is how do I prime the new Sand Filter, first time start up procedure with dirty green water?
    I am supposed to backwash and rise until the water in the glass is clear but it's not going to be because I have dirty water? Is this ok just to do anyways and start running the filter and/or vacuuming to waste?
    Another question I have is my pool came with the twist to open/close spouts from intex, the sand filter instructions say the plunger spouts are needed with this filter, is this true?
    Thanks
    38,271
    Re: New Intex Sand Filter install/Opening Pool
    The reason to do that is to wash the sand off so any small dust does not end up in the pool. Since the water is a mess anyway, I might just skip the sand startup backwash ... or you could do it anyway with the dirty water. Will not hurt anything.
    Jun 2014
    San Jacinto CA
    14
    Ok thanks, I was worried maybe you needed clean water to settle the sand to help the filtration. That takes a big weight off my shoulders. Thanks.
    My thinking here is to get water in the system, then vacuum all the mud to waste, start up the filter and add proper chems.
