Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Leaves and more leaves.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Been brushing my solar cover for the past 2 weeks. About a bushel every other day. Ran my Aquabot today (3 times!), here's a shot of 2nd run. Hate to think what the bottom would like without the cover. Hopefully the wind will stop blowing before the water hits 80. 2 seasons with Aquabot 4WD and couldn't be happier with it.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Leaves and more leaves.
    Ahhh...Wind season in Texas. So far this year in DFW, it actually has been less windy than in recent years. Today, however, it kicked up a bit. Now I have debris (mostly those white Bradford Pear bracts) in the pool from other people's trees. So, I feel a bit of your pain.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Ditto Bo!----just vac'd and skimmed. Do it again tomorrow!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    You can't get a leaf blower or a shop vacuum hooked up to the exhaust port to clear that cover off?
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Tried that, tends to blow more down the cracks at the edges. An 18" pool sweep does the whole top in about 5 minutes, just pile near the edge and scoop with dust pan (this also cleans off any bird droppings and pollen). Just frustrating, get it clean and 30 seconds later a gust adds 500 more. Just tested first time in a month an pool is almost perfect, FC 4.5, Ph 7.6, CYA 40 (going to raise to 50), CH 290, Borates 30 (going to raise to 50). I found putting 3 or 4 pucks in a floater keeps CYA and FC in check all winter without the need for Clorox. Will be starting my Steiner in a week or two though.
    DIY chlorine feed
    BBB
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Bummer. Are those live oak leaves? Do they normally fall in spring?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by woodyp
    I'll be right there with ya Woody!
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Quote Originally Posted by pooldv View Post
    Yeah, oak seems to drop in spring in Texas. Barely anything falls in the fall.
    DIY chlorine feed
    BBB
    Apr 2010
    East Texas
    9,643
    My white oaks and water oaks all come down in fall----all in the trash now! (Thank God)-----I'm gettin' too old for this.
    DFW, TX
    24,502
    Yep, my red oaks are fall leaf droppers. I have one live oak nowhere near the pool, I need go look and see if it is dropping leaves too.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I'm about to get the tassles from my Mulberries. First opening season, so I'm thinking cover stays on until most are down. I feel ya!
    No wind here at all until today minus some cold fronts. Very, very odd. I sure hope it passes us by this year. (For once)
    Essential Links:
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Just when I thought all the dead leaves were blown off... I forgot about the follow up of tassels and pollen. Solar cover is now green. Just brushed/rinsed it, and now pool is tinted. Hopefully it's all big enough to get filtered out. Will see if my CC won't go up much.
    DIY chlorine feed
    BBB
    Sep 2014
    North DFW
    161
    On my street in DFW, half of the red oaks drop in the fall, and the other half drop in the spring when the new foliage starts.
    39' x 18' IG 3.5X4.5X9 34k gallon w/ raised spa, 3 stone scupers
    Jandy 60 SqFt DE, Jandy PDA PS6, Jandy JXi400 heater, Jandy 2.0 EPump w/SVRS
    A&A Manufacturing ICS w/G4 venturi heads
    2 incandescent lights in pool, 1 in spa.
    Apr 2014
    Stony Brook, NY
    159
    Gonna order a breeze 4wd for my 16x32 IG. How does it do on walls??
    14000 gallon 16x32 roman in ground vinyl, Hayward 140k heat pump, swg, de filter 1 1\2 HP v.s. pump. Built in June 2014. Tf100 test kit.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Quote Originally Posted by suzook View Post
    Not great on walls, but does climb. I brush walls about once a month. Does a great job on the bottom.
    DIY chlorine feed
    BBB
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Today's oak droppings (after sweeping all off yesterday). Half cover swept today:
    DIY chlorine feed
    BBB
    Apr 2014
    Stony Brook, NY
    159
    Just picked up one of these bad boys for $539 shipped. Pool opening in 4 weeks, so im hoping she works as well as yours.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Just pulled half my cover off and ran it once, bottom clean (for a few minutes), oak is still dropping. Pool is a light shade of green from the pollen. FC tests okay with less than .5 CC, so don't think it's algae. Cleaning de filter is next, probably full of pollen.
    DIY chlorine feed
    BBB
    Apr 2014
    Stony Brook, NY
    159
    A little update om my purchase. Im leary to post the website i purchased from, their customer service was horrible. I specifically asked if the units they sell are the newer model with the tangle free cord. They assured me it was. Well, it shows up, and its the old one! Took 2 weeks of phone calls, only for them to have aquabot to call me. Seriously? Well aquabot sent me the newer model, for no charge! Old unit back, prepaid shipping! Aquabot really stood up to the plate. Great, great cust service. I will be using the new unit this weekend when i open my pool.
  20. Back To Top    #20
    Apr 2014
    Stony Brook, NY
    159
    @tcat Just used my 4wd, and wow! This guy picks up ALOT! My only issue is he sometimes does a wheelie when reversing in another direction. Is this normal?
