Future infinity pool location
What a view! That's the perfect background for an infinity edge. Looking forward to pictures of it going together. Good luck!
What you might want to do is to put up a string line where the top of the infinity edge will be so that you can get an idea of what you will see from various points around the pool. Ideally, you would only see water from the side closest to the house. The pool water should blend into the water in the distance.
Thanks Royd.
I think you will find that the drop on your site continues over a longer stretch and therefore standing outside the pool you may see the lower portion of land. If you stand far enough back, you will get the illusion you are looking for. Non the less, I like your hill top position
