Thread: DIY raise/level concrete deck?
    Mar 2015
    Plano, TX
    18
    Our new pool has some settling of the deck, most notably at the back of the yard. There is a slab that has sank on one end considerably. It's not directly attached to the coping or pool, there is a flowerbed inbetween. I am thinking of trying to fix it myself by digging under the low end, using bottle jacks to raise it back up, and adding either concrete piers or stacked cinder blocks for footings. Has anyone ever tried something like this?
    1982 built 15K? gallon IG gunite/plaster, DE filter, Pentair Challenger 1.5HP pump, Polaris 280, Pentair LA01N booster pump, 3-8' with diving board, K-2006 test kit
    Re: DIY raise/level concrete deck?
    Sounds like the same problem I had. My remedy was to use a bottle jack to raise the slab. Then I used concrete blocks and loose pebbles to pack under the slab. I lowered the jack to level and left the bottle jack under the slab and packed around it. So far so good.
