Thread: First Opening! Just a bit concerned about timing...
    Feb 2014
    Atlanta
    25
    I have searched the forum and google as well and am still quite not sure what to do... First a little thanks! We had a Doughboy oval above ground pool installed last May. We only used the troublefree method and had an amazing season of ease in regards to maintaining the water. We did cover the pool last fall with the cover that looks just like a tarp basically (green on top side black on bottom side). I am just really confused on when I should open. Very soon, here in Georgia, we will all be sitting in a heavy coating of pollen and I am concerned about keeping the filter running while I am at work because I heard it can clog quite quick due to the pollen. For those in Georgia, do you try to wait until after this has passed? I have never had green water and really don't want to start now, so I am willing to do whatever it is I have to do, just trying to decide what the right thing is... Any advise would be VERY much appreciated!
    Oh and the temps here are crazy all over the place, down into the 40's and up in the low 70's. The pool is shaded by the house a good bit of the day and isn't in full sun until about 3pm.
    16x32 Doughboy Saratoga to be installed May 2014 with deep end. 15k gallons. Hayward Powerline XP 1.5hp single speed pump and sand filter. Majestic steps. Patriot automatic cleaner. Just North of Atlanta, Half of pool gets sun all day and other half is shaded by the house almost all of the day. TF100 XL Test Kit with Speed Stir. Using TFPC method.
    Re: First Opening! Just a bit concerned about timing...
    The normal rule of thumb is to open as soon as the water gets to roughly 50 degrees. If you are trying to avoid pollen you can put that off for a while, but your odds of getting algae start to go up the longer you wait.
    Feb 2014
    Atlanta
    25
    Thank you, I will just put a thermometer just inside the pool at the skimmer mouth since that is the easiest spot to check it. It has been pretty cool here at night so hopefully that is keeping the temps down under the cover. I will stop and get a new thermometer tonight, the kids destroyed the poor shark from last year... LOL
    Casey's Avatar
    SW PA
    10,428
    If you want to open now, do so and leave the pump off while at work and run it when home, checking the skimmer box regularly.
    Feb 2014
    Atlanta
    25
    Ok, thanks, would there be any issue with it settling down and becoming a problem? I know I want to at least wait until I get my refills for the TF100, but with me being in Georgia they come fast. I don't mind leaving it closed a while longer I just don't want green.
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    open the pool, but don't take the cover off. That way you can get your FC where it needs to be if you wait longer
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
