Thread: Jandy AquaPure Timer Question
    Mar 2015
    Tampa Bay Area, FL
    12
    I had a new pool installed last year.
    I'm in the process of installing a heater and having the equipment moved. This triggered me to read pages and pages of manuals recently, so brings my question:
    They (pool builder or electrician ) hooked my SWG to a mechanical timer located inside the outside sub panel.
    After reading the manual for my vsFlowPro pump, it states there is an auxiliary power bar that will provide 230v/11a when the pump is turned on.
    Is there any reason I wouldn't want to hook the SWG to this power bar? It would appear to be a much more reliable way of checking for water flow than trying to sync two timers?
    10,000gal, IG, Pebble-Tec
    Cartridge Filter, Jandy FS-Flow variable speed, with Jandy Aqua Pure SWG.
    Completed 4/14
    Jun 2011
    Long Beach, CA
    2,781
    Re: Jandy AquaPure Timer Question
    I would switch it over to the pumps auxiliary power. You want the SWG to only have power when the pump is on and that would be your best option.
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    Quote Originally Posted by ping View Post
    Yup, thats how mine is set up.
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
