Results 1 to 8 of 8
Thread: Low PH and low CYA
    Jul 2013
    Waxahachie, Tx.
    442
    Low PH and low CYA
    Just wanting a thumbs ups or down on my approach.
    First of all in N. Tex we have had a lot of rain the past month. I pumped water out of the pool twice in a 4 day period. When the level reached the top of the skimmer opening I would pump down to mid level of the skimmer(approx 2.5"). Like I said did this twice. Been using bleach to supplement the FC during the winter. Here is the full test results from 2 days ago.
    FC 4.5
    PH 7.0
    TA 110
    Ch 250
    CYA 50.
    Water temp 69
    So, I believe the reason for the low PH and CYA is the influx of fresh water. So according to pool math I am in the process of adding 19 oz of stabilizer and aereating at the same time to combat the low PH and the drop that will occur during the stabilizer addition. Or should I go straight to liquid stabilizer to prevent the PH from dropping any further?
    Am I processing this correctly? Thanks for any inpit
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
    Re: Low PH and low CYA
    You are doing fine. There is no reason to use liquid stabilizer.
    38,237
    I would just aerate and use the stabilizer granules ... although no huge hurry on raising the CYA. Mine is also around 50ppm right now, but the water is still cool and the sun is not intense enough to really need it higher yet.
    Jul 2013
    Waxahachie, Tx.
    442
    Thanks everyone......see I am getting the hang of this. So easy...just reasurrance. So should I stop the stabilizer addition until it gets warmer
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I also vote for holding off on the stabilizer addition for now. Are you running your SWG or are you still maintaining FC with bleach?
    Jeff
    Jul 2013
    Waxahachie, Tx.
    442
    Running swg
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You're fine, and yes forget about liquid Cya. It really isn't a good buy compared to dry.
    Essential Links:
    Jul 2013
    Waxahachie, Tx.
    442
    Thanks everyone
