Thread: Adjusting return jets...
    crashd0g's Avatar
    Jan 2015
    Punta Gorda, Fl
    17
    Ok, it sounds like there are some general rules (use the jets to get good water movement away from the skimmer barely rippling the water surface, but create a rotation so that the old water gets pushed by the skimmer). Sounds well and good, but then I look in my pool and wonder exactly how do I apply those basic principles... A picture to help with the discussion:
    So, the basic idea for this pool, is that water is pulled out via the drain on the bottom (deep end of pool 5' deep) and the skimmer (shallow end of pool 3' deep). Water is returned to the pool via the spa (which overflows via water fall into the main pool), return jets, and the bottom clean out system.
    Just to keep things interesting there are 2 types of return jets:
    Of the 7 return jets in the pool, three are of the type on the left and four are of the type on the right. If you start numbering with the lower right corner as 1 and go clockwise, the three jets are 1, 3, 7. They can end up in any position if different locations would be deemed better.
    From what I see, the difficulty is that the waterfall pushes water away from the skimmer and it's difficult to see water getting past that to be skimmed. It happens because I see stuff in the skimmer basket, and I would like to do what i can to make sure the circulation is as good as I can get it with what I have. BTW, it seems like the bottom clean outs and the return jets have water allowed through them in a rotating fashion (one or two jets at a time, and then the bottom clean outs one at a time, on about a two minute cycle).
    My questions have to do with how to adjust the valves controlling how much water is sent to each of the three return systems, and how to point the return jets. So, comments, suggestions, or questions are all welcomed to help me learn what I'm doing...
    30x13 irregular shape with a 6' dia spa - ~12K gallons. 3' - 5' deep, gunnite construction, built in 2006. AquaCal Heatwave H120 Pool Heat Pump. Pool Pilot Digital SWG (DIG-220). Pentair Compool Lx100. Pentair Whisperflo Pump 2.5 HP 230V 011775. Century Electric B855 2-Horsepower motor. Pentair CC150 cartridge filter. Single skimmer, bottom cleanouts.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Adjusting return jets...
    I would set your return jets to generate a counter clockwise flow, the waterfall will also help with this. About equal flow to all. Should work like a charm! Also, I would only turn on the waterfall when you are out there, not all the time, it will raise your ph and increase evaporation.
    crashd0g's Avatar
    Jan 2015
    Punta Gorda, Fl
    17
    so, you would not have water circulating through the spa except when we are out there? I tied to balance out the spa drain along with the input into the spa so that water would still circulate, but it is nearly impossible to balance out.
    DFW, TX
    24,509
    Sorry, for your filter cycle, yes, you do need to circulate water through you spa. Seems like it will work counter clockwise even with the overflow running.
    crashd0g's Avatar
    Jan 2015
    Punta Gorda, Fl
    17
    Yup, I set the jets to counter clockwise and was able to watch some debris move around on the surface and end up in the skimmer in about 4 minutes time...which is two cycles through the return system...
    38,475
    Usually in spill-over mode, you do not want to have any suction from the spa ... because like you said it is hard to balance. Or at least you want to be sure that there is more water going into the spa than there is being sucked out.
    You might want to consider seeing if you can run most of the pump time in Pool only mode and just run in spill over mode for 30-60 minutes a day to maintain chemical balance.
