Results 1 to 17 of 17
Thread: Spa - raised or in pool with kids
    Jul 2014
    New England - MA
    310
    As we finalize our pool design I'm torn between a spa that sits inside the pool vs a raised spa. We'll be adding an autocover and the integrated spa option gets covered as well. My wife is concerned the children (we have 3) will get hurt on a sharp corner if the spa is in the pool.
    Any one have the spa in the pool with kids? Would love to hear your feedback.
    Example of what in talking about.
    2015 Pool Build --> HERE IG 19'x47' w/ 7'x7' in pool spa; 3'6"-8' deep.
    Pentair 520 Filter, IntelliFlow VS XF Pump, IntelliChlor IC60 SWG, IntelliBrite/GloBrite LEDs, IntelliTouch w/Screenlogic2. 400K BTU heater. A&A G4V in-floor cleaning system. WetEdge Prism Matrix Pebble finish. TechoBloc Pavers and Coping.
    Test kits - Taylor K-2006 FAS/DPD, K-1766 Salt, SpeedStir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Spa - raised or in pool with kids
    Yeah, I could see someone trying to make a diving catch into that corner. Doing a radius around that corner ought to solve that and should be easy enough for the PB.
    Jan 2015
    Tx
    15
    We used that exact picture as inspiration for our pool build. After much discussion with the builder and family, we decided to raise the spa 18" with a standard overflow. The area next to the spa we did a tanning ledge for the kids rather than just steps as in that picture. Safety and aesthetics were the reasons for raising the spa and I am happy with our decision. Looking at that picture again I think we would of been happy either way, and I have already had a kid "seal dive" from the spa overflow into the pool so Im not sold on one being safer than the other. A cover was not part of our decision and I can see how that would be a big factor.
    This is a bad picture but an idea of our layout which we are really enjoying. The kids love the tanning ledge and steps, and the adults love the spa and bench in deep end.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Though I see they have an autocover in the picture, I would not recommend having that sharp corner which the cover will have to drag over each time it opens and closes. Not to mention when it rains and you forgot to put the cover pump on, the weight of the water pulling the cover down will surely stress that area more quickly, and lead to a premature tear. Ideally, I'd find a design way to round off the outside edge of the entire spa. Perhaps a stone mason with real talent could do it with some thick PA bluestone, which is what the picture appears to be show. Any raised spa will also impact the cover operation though they can certainly be done.
    As a side note, the bluestone coping on that pool is fairly thin, probably 1 - 1 1/4" thick (the same as mine). Though at first glance you may want thicker (and give consideration to if you want the thermal treated surface variety), the downside to thicker with an autocover is that the deck level becomes much higher than the water level. The integrated autocover rail adds about 1" above the tile, then 1/2" or more of grout then the coping. If you want to see some closeups of this scenario, see our build thread, the link to which is in my signature.
    Best of luck with your project. With that as an inspiration photo, I'm sure it will be great!
    Also feel free to document your build, continuing right in this thread, so information all remains in one place. We'd all love to follow your experience - and we love pictures!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Sep 2014
    Alamo,California
    14
    We also used that pic for inspiration but due to our flat lot we wanted to add some elevation with an 18" raised spa. Makes the autocover easier to manage, and allowed for a larger bench. Besides my wife wanted the extra benefit of a water feature we can run with the cover on for sound.
    16'x32' 15,000 gal, 7'x7' Raised Spa, Coverstar Autocover, Stonescapes Mini Pebble - Midnight Blue, Intellichlor IC40, Pentair Mastertemp 400BTU NG Heater, Pentair 420 Sf Cartridge filter, Intelliflow VS+, Dolphin Z5, TF-100
    rodog123's Avatar
    Nov 2013
    Pearland, TX
    308
    Raised spa as this will give you another water feature.
    Completed 38'X21' IG Free form pool approx 18.5K gallons, sports pool w/spa and tanning shelf 3.5-5.5 ft. Jandy Cartridge Filter, Jandy stealth pumps, Jandy LXi Heater, I aqualink, Inline chlorinator. Click to see My Pool Build
    Kpag's Avatar
    Feb 2015
    Dallas TX
    159
    Our spa is "in" but our 1988 pool is freeform with the spa "attached". We are getting ready to renovate our pool and looked at having the whole spa raised (to add water feature and focal point). Our kids are 9 and 12. I can also see safety issues either way. We always have kids "walking" on the wall between the pool and spa which isn't very safe either even though there aren't sharp edges. Kids just do dumb things around a pool! See pics here:
    http://www.troublefreepool.com/threa...044#post758044
    IG ~12000 gallon 1988 freeform pool with IG spa, Hayward equip, Ecostar pump. Remodel done: NPT Arctic 1x2 tile in Lagoon w/ gray thinset & Light Pewter grout, French Gray PebbleSheen w/ grey fittings, Leuders buff eased edge limestone coping w/ Light Buff mortar, buff mastic
    wjr75's Avatar
    Jun 2013
    IL
    836
    We have a slightly raised spa with a small spill over next to our rectangular pool. We have the auto cover that covers the rectangular pool and use a three piece spa cover for the spa. There is a small cut out that still allows the spa spill over when the auto cover is closed. We can close/winterize the pool in the beginning of October and still keep the spa open. We usually close the spa in December since I don't like running pumps in freeze protection once the temp stays below 32 degrees. I see you are in a colder climate so you may want to consider a setup such as this.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jul 2014
    New England - MA
    310
    Thank you all, lots of great suggestions.
    The diving football catch into the corner is exactly what my wife is worried about. Perhaps rounding the corner can maintain the look and add a bit of safety. I've seen v-cap glass tiles that could potentially serve to round up the edge enough to prevent tearing someone open.
    Great point on the cover wear from the sharp edge and rain weight. If I go in pool, I'm now considering a design that would have the edge close to pool water level. I read about methods of reducing pool water height when spa is activated so spa edge is 1/8" higher than water level. When spa gets turned off - pool autofills. I imagine that could potentially just make it more difficult to balance chemical levels with all that dumping and adding of water...
    I could go either way at this point, my architect likes the clean lines of the spa in pool. Haven't priced out the different options to see how they compare. Will speak to PB and definitely report back and add lots of pictures.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Water chemistry shouldn't be an issue as you will be mixing the water daily so chemicals will be kept mostly the same. You will not be maintaining two separate bodies of water. To note also, the spa in this setup is not designed to be kept hot all the time but heated on demand. At least that's my understanding...I don't have a spa. Others can confirm.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Another vote for raised spa: Mine is 18" above the pool height, and when we have a lot of people visiting, it makes a great place for people to sit. It's the perfect height for an outdoor bench!
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Feb 2015
    Pasadena, CA
    58
    Quote Originally Posted by spool View Post
    We went with a spa just barely above water level and so far (short so far: we got water last week) we love it. We have an autocover as well and it never hits the spa coming across. It looks beautiful when the filter is running and water spills gently from spa to pool.
    We considered a raised spa with separate cover but I knew the separate cover would add inconvenience and I could see scenarios where it was left open "just for now" and became a hazard.
    Our pool:
    Nearing completion on (owner/builder) 30k gallon pool.
    37 1/2 by 20 rectangle. Raised bond beam with custom water feature.
    Mazzara glass tile. Bellecrete coping. Quartzscapes finish.
    Pentair DE Filter with easy touch
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    My spa is at the same height as the pool. I like it that way. The spillway is a few inches above the normal surface of the pool, so there is that waterfall effect. But never ever have I posted one of the numerous "My spa is draining into the pool" threads. Keep the pool square for the auto cover, but make a gentle S-curve so the spa has rounded sides. Fewer sharp corners that are a pain to brush that way, too.
    Feb 2015
    Pasadena, CA
    58
    Took a few pics of cover clearing spa with ease:
    Not dragging at all.
    Jul 2014
    New England - MA
    310
    Thank you for the pics. That is the design we decided on. Will start a new build post soon.
    Sep 2015
    Parkland/ Florida
    3
    Do you have any problems with the pool water flowing into the spa and preventing the spa from getting hot. We have a new pool with the spa similar to yours. They built it with no overflow mechanism and only 1 pump. What did they do for your pool to ensure that you don't have this problem and have to keep back washing the pool every time you want to use the spa after it rains.
    Jul 2014
    New England - MA
    310
    Pspeech, I responded to this in my pool build thread and also PM'd you.
