Results 1 to 8 of 8
Thread: Startup? What Startup? NO STARTUP after BBB!!!!!!!!!!
    edge's Avatar
    Mar 2014
    Douglas, GA
    143
    Hey guys! Long time no see!
    Last year I joined to get answers and help with my large in ground pool. I had let it go over the winter and it was a total mess come spring last year. I wasted tons of money getting pool stored until I found this place and switched to BBB. Long story short, My CYA was sky high due to trichlor and I had to drain the pool and start over.
    Fast forward a year. I didn't shut the pool down over the winter. We have mild winters here in South GA and I don't have any trees hanging over so there's little debris getting in the pool. I kept VERY LITTLE chlorine in the pool over the winter. Literally prolly NONE for most the winter but due to water temp, it wasn't an issue. I did let it run about 6 hours everyday. This year my startup consists of me SLAMMING with bleach and testing the water. I have only vacuumed to waste once and if my water temp was up the pool would be ready to go. I cannot describe how much easier it has been and more affordable to use the BBB method and run the pool year round instead of closing it which does increase my light bill but it's worth it. I do not have any current pictures but the pool looks just as good as any i've ever taken. So this is basically what my pool looks like today and has ALL WINTER...
    The ONLY thing that needs to be done to use this baby is the water temp to rise about 20 degrees!
    16'X32'X8' Vinyl Pond with Diving Board (Neck Breaker), 1.5 hp FOXX WhisperFlo(Not so quite anymore), Massive Lawn Egg (aka: Sand Filter), Coolcrete Pool deck (Burns feet to a crisp), Large wooden Multi level deck (Splinter City) with fire pit in center (Insurance company's nightmare.)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Startup? What Startup? NO STARTUP after BBB!!!!!!!!!!
    So.... overall.... do you think the test kit was a good investment?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Beautiful! You have learned well!
    Love TFP? Become a
    TFP Supporter!
    edge's Avatar
    Mar 2014
    Douglas, GA
    143
    Ohhhh Yes! I had spent that much nearly 10x over trying to get it right. Without the CYA I was throwing darts in the dark. Very pleased with the Kit and the method. Honestly I usually use Muriatic Acid to control PH and Bleach to add Chlorine. Thats the two things I use anymore. Sooo simple. I just need to find a way to get Bleach in a 55 gallon drum. lol Any ideas?
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Funny. I was born and raised in Georgia, but lived in a lot of places since (now live in Texas). In Georgia, anything that uses electricity is called a "Light Bill" even if its a pool pump or refrig, or air conditioner, that's all part of the "Light Bill".
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    LOL Thats what we call it in East Texas too!
    My light bill is too high!
    Quote Originally Posted by epro05 View Post
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I love it!!!
    Another TFP Success story. Great stuff, and congrats on whipping it into the way YOU control it. Awesome.
    Essential Links:
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by edge View Post
    Look for a chemical supplier in the area. You may be able to get a drum. We get 300 gallon totes at work to use on the cooling towers when the chlorine plant is down.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
