Results 1 to 15 of 15
Thread: Pump run time recommendation
    Feb 2015
    Santa Clara,CA
    46
    So I read - http://www.troublefreepool.com/conte...-pump-run-time.
    According to this I should run my pump for around 4 hours (single speed pump).
    But my pool guy (who I fired) and the store guy mentioned that its better to run it for about 7-8 hours.
    Their thumb rule is 1 hour for every 10 degrees of weather.
    Right now, it is set to run for 8 hours at night and the weather is around 70.
    My chemical levels are (I do not want to replace any more water due to severe drought. I already replaced about 40% to bring the CYA level from 200 to 100).
    CYA - Around 100
    FC - 8
    CH - 625
    TA-160
    PH-7.5
    Do the experts here have any recommendation of how much the pump run time should be for my pool.
    Thanks a bunch,
    -Prasad
    30,000 gal,20'x40' IG (3-8.5 with diving board) ,Plaster,Pentair S8D110, Type of filer - DE,TF-100 test kit
    Poolsafe Automatic pool cover
    Jan 2013
    Friendswood, TX
    320
    Re: Pump run time recommendation
    Not an expert but I believe you need to get the TA down. I believe you add muradic acid and then aerate to bring the PH up.
    I run my pump 4 hours or so with Texas heat. I have a SWCG so I determine run time on 1) FC and 2) water cleanliness. Since you use bleach (I assume as a SWCG isn't listed) you need 30 min or so for the FC to mix then it's cleanliness I believe.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Just so I'm clear on this....
    The pool guy and the pool store salesman managed to get your CYA up to 200 and you still listen to their advice?
    Our answer is in that article.
    Shorter pump run times are a fairly new discovery. Everyone though that longer run times were important, but it turns out that everyone was wrong and shorter run times are just fine for a residential pool. Commercial pools are a whole different story. It turns out that the main function of the pump is to clean up surface debris, and it can do that rather quickly.
    Feb 2015
    Santa Clara,CA
    46
    Haha. Pool guy got it to 200. Store guy asked me to remove water and around the same time I discovered tfp
    So just to remove debris especially in a covered pool, I assume 30 mins to an hour is good. How about when I add acid or chlorine?
    Jan 2013
    Friendswood, TX
    320
    I can add MA to adjust PH and brush and run pump for 30 minutes and the ph has settled down. Some chemicals take longer (CYA adjustments can take a week to register). Bleach and muradic acid additions should take 30 minutes.
    Baking Soda for TA has taken longer in my pool. And hour or two.
    ~Paul
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Pras,
    pour your bleach slowly in front of a return. Then let it mix for 30 minutes or so.....
    Quote Originally Posted by prasadkm0204 View Post
    Divin Dave,
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    sorry, sorta hijacked ya.
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    The OP is trying to learn, and asking here to figure this out. He only referenced what was said before.
    Prasad, it's more likely that a few hours a day will be about right in the end. You can work it down from the 7-8 hours suggested until you find a point where you have too little run time set. If you find that a few hours aren't enough at some point you'll noice you need more circulation time. You can always add a little time if you see it isn't enough.
    Essential Links:
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Quote Originally Posted by Patrick_B View Post
    What should someone look for "where you have too little run time set". Is it cloudiness, debris on the surface, debris on the bottom, particles seen in the light at night? What characterizes enough filter time?
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    Everything you said except cloudiness. Cloudiness is chemistry, debris is filter time. Debris will usually ramp up in spring and fall and down in summer and winter.
    Feb 2015
    Santa Clara,CA
    46
    I reduced the pump run time from 8 hours (at night) to 4 hours (day time, so I can increase as required while its running).
    I'll observe and see how this goes.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes, you'll be able to tell if you have enough filtering to keep it skimmed and clean. Don't be surprised if 4 hours is plenty.
    Essential Links:
    Feb 2015
    Santa Clara,CA
    46
    4 hours of run time so far seems good so far.
    I reduced it to 1 hour over the weekend to see how it goes.
    Given that I have a pool cover there is hardly any debris.
    I'll observe how this goes.
    DFW, TX
    24,496
    Nice! Should work great with the cover. And once spring passes it should be even better. Busy season for filtering is spring and fall, summer and winter are usually pretty low key.
