Results 1 to 10 of 10
Thread: Lower cost variable speed pump that will link with a solar controller?
    Oct 2014
    Bay Area, California
    146
    I was looking at the hayward max flow sp2302, http://www.amazon.com/Hayward-SP2302.../dp/B00OLSWQS6
    But it was brought to my attention that that pump has no provisions for being controlled by anything external. For example I can't have the pump turn on or ramp up when the solar controller calls for heat. I am not sure if this is something I for sure want, but it would be nice to have the capability to add this feature in the future i suppose.
    38,275
    Re: Lower cost variable speed pump that will link with a solar controller?
    Check the SuperFlo VS ... I think it might have external control abilities.
    mas985's Avatar
    Pleasanton, CA
    11,737
    The SP2302VSPND can be controlled by any Hayward controller. It is a newer version. It is the SP2300 and the SP2302VSP that cannot be controlled.
    See page 11: http://www.hayward-pool.com/pdf/manu...-IS2302VSP.pdf
    Mark
    38,275
    Ah, good info. Looks like Hayward fixed this apparent oversight.
    Oct 2014
    146
    Hmm, for some reason I thought I could directly link the pump and solar controller.
    38,275
    What solar controller do you have?
    Please add your pool details to your signature as described HERE as it will help us help you.
    mas985's Avatar
    Pleasanton, CA
    11,737
    What solar controller? You might ask Hayward directly because they don't always list everything that is compatible.
    Mark
    Oct 2014
    146
    Well right now I have a very old compools unit. Im trying to decide if I should revive it or get a one that can control the pump. Looking at the hayward controller, it only has a high voltage output. Meaning if I had an old style pump with no timeclock I could control it, but it doesnt link with the pump http://www.hayward-pool.com/pdf/manu...olarGL-235.pdf
    Yeah I know my signature is lacking, I have been putting it off because I am replacing all of the equipment etc.
    Oct 2014
    146
    signature updated
    Approx 15,000 gallon gunite pool, fiberglass finish. Hayward SP2302VSP, compools solar controller, 6 4x10 "Sealed Air" brand solar panels, Clean and Clear 520 cartridge filter
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Hayward has two pumps, EcoStar(2hp impeller) and TriStar VS (1hp impeller) that can be linked via relays, if available, or through the actuator ports on a Compool. A little complicated but it can be done. I strongly recommend if you get a variable speed pump you purchase a control matched with that pump. Private message me if you would like to talk.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
