Thread: Pouring acid into IntelliPH (or other canister)
    Aug 2014
    Mesa AZ
    54
    Hi - I just got my new system + IntelliPH installed. I went to pour in the acid to the canister and thought I was pretty careful and kept my head as far away as possible while pouring, but got a nice whiff of acid vapor. Nothing serious just a quick cough and I moved away.
    Is there a safety 'trick' to doing this well? It also seems to splash a bit more than I'd like, though this wasn't so much of a problem. Would it be worth it to lug a fan out there or something?
    30k plaster pool
    Pentair 011018 IntelliFlo, Pentair CCP520, IC40 SWG, IntelliPH Acid system
    Easytouch 4 + ScreenLogic2
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Pouring acid into IntelliPH (or other canister)
    biggest thing I've been able to do was stand upwind as you pour...not above and certainly not above and downwind.
    I assume the container you are pouring into can't be tilted while you pour? If it can, then you can minimize splashing by doing that.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Mod Squad pooldv's Avatar
    DFW, TX
    24,491
    yes, the wind is your friend when pouring acid. Otherwise you need a pretty fancy respirator.
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    I usually cover my mouth and nose with a tshirt hold my breath and turn my head away as much as possible while being careful not to let it splash out. I usually try and aim for in between the plastic parts.
    If you get a breathful walk away and air yourself out before trying to finish.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Try to stay upwind and away from the vapor. You may be able to use a long funnel to minimize the splashing. Lowes sells a chemical respirator that you can use for about $30 if you want to completely avoid inhalation. I don't know if the one they sell has replaceable cartridges or not. Amazon has one for $24 with replaceable cartridges being about another $9. Still have to watch your eyes unless you get a full face respirator.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
