Thread: Borate Test
    Aug 2014
    Shallotte, NC
    693
    Borate Test
    Referencing this thread:
    http://www.troublefreepool.com/threa...-vs-test-strip
    Is the test using existing Taylor Reagents still documented and/or obtainable somewhere? The links are broken....
    Re: Borate Test
    No, that test hasn't been available for a while. Only some of the reagents were from Taylor.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Borate Test
    The links in this post to mannitol powder and bromothymol blue indicator dye both available at Amazon are still active links. My post after the linked one describes the procedure. I still have my original kit and it still works reliably (I just tested my borate level last week both with the kit and with LaMotte test strips). Apparently, this indicator dye is pretty stable.
