Results 1 to 7 of 7
Thread: Warranty Shell Game
    Aug 2014
    Shallotte, NC
    693
    Warranty Shell Game
    I was looking at the warranty for our proposed new pool liner and found that one of the exclusionary clauses was "improper chemical utilization." So, I write the manufacturer and ask what proper chemical utilization is and I get a response to ask a pool store. They just "manufacture" the liner, not the vinyl, so they can't tell me anything. Apparently, they don't even know their web site offers pH 7.2-7.6 and TA 80-120. Nothing about sanitizer, etc.
    So, anybody with information about how a warranty claim is processed? Who decides? Etc.?
    I'm not expecting a warranty claim, but given what I understand, there is no warranty, just a lot of finger pointing.....
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Warranty Shell Game
    Virtually the only warranty you are going to get for a liner is failed seams.
    Aug 2014
    Shallotte, NC
    693
    Yeah, that is what they say in their correspondence, but their warranty also specifically mentions exclusions due to "improper chemical usage."
    UPDATE - They came back with, "Typically, if your chlorine is maintained below 3ppm and your PH is between 7.2 - 7.6 your liner will wear at a normal rate." That is almost exactly what the installer said.
    Less than 3ppm sounds like an invitation to chase algae. I'm thinking more like a target of 4ppm and 30ppm CYA. Would that be enough CYA for my location? I have a Liquidator and the pool guy quickly identified that as the spawn of the devil.... acidic liquid chlorine eats plasticizers..... must use tabs!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,423
    I think the same thing-seams only. Other than that it is no go.
    Sad for that amount of money.
    Kim
    38,251
    Quote Originally Posted by ewkearns View Post
    Well the pool guy does not know what he is talking about. The trichlor tablets are acidic ... liquid chlorine is actually basic.
    Sounds like the liner manufacturer is like most of the pool industry with no understanding of the CYA/FC relationship. Following our methods you are are probably less likely to run into liner problems because you will not be having to "shock" weekly with acidic dichlor and raising your FC too high.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Jason is right, but makers of anything pool will not suggest any FC level over 3.0 PPM because it's outside most official guidelines. Which as Jason says do not recognize FC/cya ratios.
    The pool guy does need a chemistry lesson. As Jason said, it's opposite of acidic. Sigh...
    Essential Links:
    Aug 2014
    Shallotte, NC
    693
    I thought the big point he was missing was that baking soda is basic and muriatic acid is acidic, yet we still put those in the pool..... in my mind, it is all about the pool chemistry (as a whole), not the additive.... the guy has 45 years experience, but still retains some of that knowledge gained around the PB/PS campfire, kinda like B.C. and company....
