Results 1 to 8 of 8
Thread: Outdoor music/sonos
    Aug 2014
    NJ
    435
    Outdoor music/sonos
    I am building a pool and would like to put speakers around the pool and hot tub. We installed Sonos in our house in December 2007, so will utilize it for the outdoors. We already have outdoor speakers on our lower patio, but want to put speakers around the pool and hot tub (the hot tub is a stand alone). See attached image showing the pool and hot tub. photo10.jpg The next picture shows my lower patio, which has outside speakers on the walls.
    Sonos has changed a lot since we first got it. I noticed they no longer have the color remote since one can simply use an IPHONE App.
    My question is where should the speakers go. The far wall of the Pool will have a grotto and a rockledge inside and outside the pool, and the left and right of the pool will have a post lamp surrounded by some landscaping (this isn't shown in picture).
    Also, what Sonos components and what speakers should I get. Are rock speakers a good option? We are not looking for a top of the line sound system - just something that will play decent sound and cover the area well.
    Thanks
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    rodog123's Avatar
    Nov 2013
    Pearland, TX
    308
    Re: Outdoor music/sonos
    You will have to get the Sonos Amp installed some place dry and run the speaker wire to the outdoor speakers. 1 Sonos amp you can have up to 2 sets of speakers (4 total)
    Unfortunalty Sonos does not make an outdoor speaker.
    I ran 2 play ones and tested them outside one under my covered deck and another beind the pool and they worked fine as my wi fi connection still reached with no problems.
    I'm just starting out with two play ones saving up for the soundbar next.
    Completed 38'X21' IG Free form pool approx 18.5K gallons, sports pool w/spa and tanning shelf 3.5-5.5 ft. Jandy Cartridge Filter, Jandy stealth pumps, Jandy LXi Heater, I aqualink, Inline chlorinator. Click to see My Pool Build
    I know this may be a bit confusing because I cut and pasted from a Adobe file. This is the set-up I installed.
    1 C4-SR250RSK-B SR-250 Remote and Recharging Station EA $300.00 $300.00
    C4-HC250-BL-1 HC-250 Controller with MyHome and EA
    Intercom Licenses
    1 $750.00 $750.00
    1 C4-16AMP3-B MULTI CHANNEL AMPLIFIER- V3 EA $2,495.00 $2,495.00
    Customize the audio signal to match the speakers and listening preferences for each individual zone./Control multiple zones
    as a single zone with Control4 Media Scenes
    1 C4-TUN2-E-B Multi-Tuner EA $599.99 $599.99
    1 C4-XMOD XM Module for Multi-Tuner EA $199.00 $199.00
    AWR-650-G 2 WAY ROCK ALL WEATHER SPEAKERS EA
    WOOFER AND TWO TWEETERS
    12 $299.99 $3,599.88
    AW-650-W 6.5" IMG Woofer 1" Titanium Tractix PR
    Horn Loaded Tweeter (white)
    1 $549.99 $549.99
    SB-5510HD-BL 55" Outdoor TV Pro Series 1080p Full EA
    HD, 120 Hz (black)
    1 $5,595.00 $5,595.00
    1 WM46 Sunbrite 46"/55" Articulating Mount EA $465.00 $465.00
    ENS202EXT 2.4GHz Wireless N300 access point EA
    supports 802.11b/g/n devices with
    speeds up to 300 Mbps.
    1 $149.99 $149.99
    WCS10-R-EXT-ZP Wireless Contact Relay (External EA
    Antenna) - Zigbee PRO
    1 $179.99 $179.99
    B-500-EXT-230-RS Single CAT5e/6 HDBaseT Extender EA
    (230 ft.), Bi-directional IR, RS 232, and
    POC
    1 $599.99 $599.99
    B3-AUD-2 BINARY CABLE B3-SERIES ANALOG EA
    AUDIO 2 METER
    3 $9.99 $29.97
    B6-HD-1 High Speed Licensed HDMI Cable with EA
    Ethernet 1 Meter
    3 $25.95 $77.85
    1 GSD-802PS Planet 8 Port Gigabit POE EA $279.99 $279.99
    1 PATCH-CAT6-2FT-BLK Cat 6 2ft Ethernet Patch Cable (Black) EA $4.99 $4.99
    1 SR-WM-10U Strong™ 10U Wall Mount Rack EA $299.95 $299.95
    SR-WM-SWING-10U- EA
    3IN
    StrongT 10U Wall Mount Rack Swing
    Kit
    1 $159.95 $159.95
    EP-400-UPS-8PS-825 Episode 8 Outlet Stand Alone AVR UPS EA
    with RJ45/RJ11 &RG6
    1 $259.99 $259.99
    NST-CAT6-1000-BLU Cables Cat 6 550MHz Unshielded 23/4 EA
    .58mm CMG-Rated Wire - 1000ft Nest
    in Box (Blue)
    500 $0.25 $125.00
    200 CAT6-SH Category 6 Shielded Cable FT $0.50 $100.00
    quote.rpt Printed: 9/2/2013 9:27:07AM Page
    1 $1,499.99 $1,499.99
    1 EA-AMP-SUB-1D-500 Episode Digital Subwoofer Amplifier EA $999.00 $999.00
    SP-164-DB Binary Cable 16 Gauge 4- Conductor FT
    Direct Buriel
    100 $0.50 $50.00
    3.00 INSTALLATION TEAM installation w/ team of techs HR $99.99 $299.97
    Two Technicians
    Item
    Also this sub woofer that gets buried in the ground
    UOM Sell Total
    ES-LS-BSUB-12 Episode® Landscape Series Burial EA
    Subwoofer with 12 in. Woofer (Copper
    Dome | Each)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,493
    Yes, at this time sonos does not make anything that is weatherproof, so it needs to be installed under a roof, patio, etc. Which gives you two options with current sonos lineup.
    1. put play1s or play3s on a patio that is covered and aim them out toward the pool/spa
    2. buy the amp and run speaker wire to outdoor weatherproof speakers
    We are very happy with the sound field that one sonos play3 creates from its covered location aimed toward the pool.
    There is no more remote. There are apps available for iphone/pad and android phone/tab that allow you to control all of it.
    wjr75's Avatar
    Jun 2013
    IL
    836
    I'm not sure what computer you have controlling your Sonos but the new iphone apps require an updated MAC IOS to at least 10.6 Snow Leopard. Some older MAC mini's can not get this upgrade due to the processor. I was lucky and was able to upgrade for a 20 dollar fee from apple.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    DFW, TX
    24,493
    I am using android phone and tab, both samsung. My kids both use ipods to control it. I don't know anything about an ipod, but theirs are pretty old and they work fine.
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    Their discontinuance of the remote saddens me. We have one and I really like having a dedicated control device I can grab in those instances when my phone/app decides to get finicky...
    Modern Geometric-ish Social Pool (4'-5'-4') ~13' x 47'. Sun shelf. Perimeter overflow spa. RiverFlow Swimjet. Dog ramp. "Bubble Lounge"©
    Link to my patio build, completed 2013
    Link to my pool build, Aug '15 - Sep '16
    DFW, TX
    24,493
    Quote Originally Posted by platipus View Post
    You must have apple stuff. My android tab and phone work great all the time.
