Thread: DB rated bonding lugs, but what about screws?
    Aug 2014
    Allen, TX
    67
    I understand bare copper wire #8 needs to be run around the pool some 18-24" away, at least 6" in ground, connected to pool frame at 4 points, using DB rated copper lugs. But what about screws? Are there any special screws required and if so where can I buy them? Do they need need to be stainless?
    10K gallons, IG vinyl free form Radiant Pool, 1HP SuperFlo 2 speed pump, 175 sqft Hayward C17502 plus cartridge filter, Intex Krystal Clear Saltwater System CS8110 Model 54601EG, Jandy Pro Series Underwater Nicheless LED. 1 skimmer, 1 suction outlet, 3 returns, The Pool Cleaner. Pool installation in progress as of 09/24/2014.
    Re: DB rated bonding lugs, but what about screws?
    The screws should be corrosion resistant, or if underground they should be rated for burial. Stainless is always a safe choice, though other things are often acceptable. In many cases the lugs can be fit onto existing bolts holding the wall together.
