Results 1 to 10 of 10
Thread: Which is best salt test METER?
    Mar 2015
    Huntington Beach/CA
    11
    I'd like to ask which salt test meter is considered the best and why? I know that there are a few different brands like the Hayward and LaMotte, etc. But which one is considered the best as far as accuracy, durability, and cost of ownership?
    I did a search on salt test meters and when forum users asked about testing meters for salt other testing methods like the Taylor K-1766 test kit and the Aqua Chek test strips are mentioned. But I'm curious on others opinions on meters only. Which METER is best and why?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Which is best salt test METER?
    Hi,
    welcome to TFP.
    The question is why use a meter anyhow? They are expensive and very prone to inaccuracies, so the answer is actually that none of them are best for use on a pool.
    Quote Originally Posted by oceanrider View Post
    Divin Dave,
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Sorry, I know nothing about salt meters. Are you servicing pools as your business? I could possibly see a salt meter for that purpose.
    As a pool owner it's not something I plan on checking on a regular basis. The salt doesn't get "used up" making chlorine or evaporate. The only way the salinity will come down normally is if you flush out your sand filter with pool water and then add tap back in to refill the pool. I guess a pool leak would reduce salinity but that would be the least of your worries. I plan on checking salt levels about twice a year. For that I compare the strips agains the level shown on the SWG.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    http://www.myronl.com/products/ultrapen_pt1.htm
    If you want one, this company makes some of the best hand held instrumentation money can buy. If you don't mind spending $160 on a hand held meter, you can't go wrong with one of these. This entire line of "pens" is somewhat new for MyronL, but they are getting rave reviews in the water treatment industry. I've carried a version of the 6P ultrameter for about 14 years, and can't do without one.
    Essential Links:
    Oct 2007
    Valrico, FL
    542
    Most "salt" measuring instruments are actually TDS meters. Don't actually read the amount of salt, read the amount of TDS. Other chemicals in the pool water also affect the TDS reading, for example CH, TA etc.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by dschlic1 View Post
    This one has a factor it calculates for salinity. Its based on an algorithm and it has one for three measurements. TDS, Conductivity, and Salinity.
    It can be done using the differing calculation factors. Pretty common stuff in good meters.
    Essential Links:
    Mar 2015
    Huntington Beach/CA
    11
    Quote Originally Posted by Patrick_B View Post
    Thanks for the suggestion Patrick.
    Mar 2015
    Sydney, australia
    21
    Isn't it just as easy to use the K-1766?
    32,000 litre in-ground painted concrete pool
    Zodiac Tri-Mid +ph SWG
    Solar pool heating
    Taylor K-2006 test kit
    In Sydney, Australia
    38,295
    Quote Originally Posted by Wandersen View Post
    To me it is, especially with a SpeedStir. Cheaper, no need to worry about calibration and maintenance, accurate enough for pool needs ...
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I agree, a Chloride test is more than adequate.
    But no, it isn't just as easy to use a salt test kit.
    You take the pen, submerge the end of it in liquid, and push a button for your reading. Its just a question if it's worth the money...
    Essential Links:
