Thread: Return Jet Noob
    michaelrbanks's Avatar
    Sep 2014
    Cibolo, TX
    89
    Return Jet Noob
    Okay, how do I adjust the direction of these?
    16,661 gal IG PebbleTec w/ Spa; 60 ft2 Jandy DE filter, 2 HP Jandy Variable Speed pump; 2 skimmer; 400K BTU Jandy heater; Polaris Sport; opened 9/15/14; TF-100 test kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Return Jet Noob
    Can you loosen/unscrew that outer steel ring and readjust the eyeball?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Re: Return Jet Noob
    stick a screwdriver in it and use the handle as leverage to repoint the eyeball.
    Divin Dave,
    Sep 2014
    Cibolo, TX
    89
    Re: Return Jet Noob
    I thought about trying to twist the outer ring, but it was too slick - maybe with a strap wrench? I may also try the screwdriver, but that seems like it carries a high likelihood of damage.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Return Jet Noob
    A small towel or washrag will usually give enough grip to loosen it.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Re: Return Jet Noob
    Ive used the screwdriver on mine probably 50 times without an issue. But thats just me I guess....
    go for the strap wrench if your antsy about it.
    Divin Dave,
