- May 3, 2007
- 16,886
- Plaster
- Hayward Aqua Rite (T-15)
They shouldn't so it must be something else.The check valve is a swing valve, not a spring valve and I installed it for the solar. Do some swing valves have a lot of head loss?
That would make things worse not better. You want higher pressure at the VRV and bypassing only lowers the pressure.Isaac's idea of the siphon effect make sense but hydraulics aren't even in the realm of my specialties. Maybe I need to divert some water directly to the return instead of 100% to the solar. I think I tried that last summer but I can't remember for sure.
Maybe you should try removing the VRV and using a plug to get a good seal. The other possibility is that at the top of the panels, there is a small leak and that is sucking in air.
If it were me, I would try to figure out what is wrong with the current setup. A higher head pump may or may not fix the problem so there is some risk there.This also plays into the question of getting a pump with a higher curve. I am less concerned with electric costs and more with warming the pool which keeps my wife happy.
Just an FYI, I have a 1/2 HP pump with a head curve similar to yours and that runs solar on a two story roof.
